Old 03-19-2010, 03:03 AM   #1
CanadianGMC
8 Lug to 5 Lug conversion
Hey everyone,
I'm thinking of buying a front end(and potentially a rear) from an 84' 3/4 and I'm just wondering what I would need to do to convert the 8 lug set-up to a 5 lug. Is it just a matter of swapping hubs? If so I plan on getting drop spindles anyway. I'm still fairly new to this so any help is appreciated. Thanks!
CanadianGMC is offline   Reply With Quote
Old 03-19-2010, 03:18 PM   #2
62gmc910
62gmc910's Avatar
Re: 8 Lug to 5 Lug conversion
The 8 lug c 20-25 stuff is a similar design but it will go a lot smoother if you start off with a 73-87 c10-15 with 1 1/4 rotors
I believe the ball joint tapers are different sized and the sockets in the lower control arms are usually different so by the time you make every thing fit you are better to start with the right parts
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 03-20-2010, 12:24 AM   #3
Captainfab
60-66 Nut
I agree, this is the better way.
Although as an alternative, the '88-'98 1500 and light duty 2500 spindles, balljoints, rotors, calipers and such will fit the earlier C20 control arms. The 1500 rotors will give you 5x5 bolt pattern and the light duty 2500 will give you a 6x5.5 bolt pattern.
