Old 03-19-2010, 07:58 AM   #1
Kevin McPherson
Kevin McPherson's Avatar
67 body/91 frame swap
I Have a 1967 suburban project I am about to start on,that is putting it on a 91 suburban frame. Has any one done this? If so what problems will I run into? Is the frame going to be compatable?? I think I have seen a finished project of the same caliber on here.any help or advise will be welcomed
Kevin McPherson is offline   Reply With Quote
Old 03-19-2010, 08:56 AM   #2
au03z71
au03z71's Avatar
Re: 67 body/91 frame swap
Maaaajor frame differences... Someone else will undoubtedly have to chime in as I have never done this. However, I'm fairly positive it will be a bigger PITA than it's worth.
au03z71 is offline   Reply With Quote
Old 03-20-2010, 12:36 AM   #3
capev86
what is the problem with the stock 67 frame? if both are 4x4's.....just graft in the front and rear chassis components. if both are 2wd.....just swap in the 91 front brakes. the 2wd's on this era are awesome with their race car rear end. a sway bar and poly bushings on the trailing arm and track bar is all that's needed to make it perfect. i think leaf springs are ugly, but gm decided to go cheap after '72
capev86 is offline   Reply With Quote
Old 03-21-2010, 08:09 PM   #4
Kevin McPherson
It is 4x4,and I am hoping to be able to get more driveability,the thought has crossed my mind to swap the drivetrain onto the older frame,but the springs are wider,and I think the frames are as well.I was just hoping to run across someone that has already swapped frames and get a few pointers.I havent started anything yet so anything is still open!
Old 03-21-2010, 09:38 PM   #5
capev86
there is a TON less fabrication involved just moving some spring perches over than trying to adapt the frame. the stock frame fits correctly, the 91 frame wouldn't look right unless you tweaked it to nearly resemble the 67 frame anyway.
Old 03-22-2010, 12:39 AM   #6
Kevin McPherson
Thank you, that made up my mind as to what I will do.
Old 03-22-2010, 10:18 PM   #7
jbclassix
Junk Yartist
jbclassix's Avatar
Hey! I am working on a similar idea! You can check out my thread if you want...
http://67-72chevytrucks.com/vboard/s...d.php?t=380183
I am moving VERY SLOW on it right now... that thing called work gets in the way of Burb time. My parts truck is a 91. I was thinking about swapping the frames. I am going to see what's involved when I get back from California. Not sure which way I am going to go, but I am going to use the power train and interior for sure.
jbclassix is offline   Reply With Quote
Old 03-24-2010, 07:55 AM   #8
Kevin McPherson
jb classix
I like your 'burb,GMC have always looked better to me.how difficult do you suppose putting rear seats that fold down out of a 91 suburban will be?
Old 03-24-2010, 04:35 PM   #9
jbclassix
Junk Yartist
jbclassix's Avatar
I think the seats will involve minimal fabrication. I need to fab a panel for the side latches, and then some brackets to mount the stops. We will know pretty soon! She is getting kicked into high gear when I get back from Cali!
Old 03-25-2010, 07:46 AM   #10
Kevin McPherson
We might have to meet somewhere in the middle some day and compare rides or MOAB or.....
