rearend...
Ok I have a 66 c10. With a 283, 3 on the tree. And what I would like to do use my rearend out of a 96 silverado with a 308 gear in it. Also put 6 lug axles and drums out of a 4x4 of the same. Can it happen??
Re: rearend...
I believe it is about 3 inches wider at the hub faces at least on the 4x4s
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: rearend...
The '88 and newer rear ends are a good 3" wider on the 2wd's as well. I would either look for a '87 and earlier rear end, or just put 3.08 gears in your current 12 bolt. You could also bolt on a set of the wider rear brakes from a '75-'80 or so 4x4.
