68cst_ss490
Got myself a serp belt setup off a 90 chev, it has an idler where the a/c comp should be in case i want to run a/c later on. I think I am going to spray it with this oxide removing stuff we have at wrk and get it nice and brite again and then clear coat them if it turns out good. If not I will paint it all black
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
"See the U.S.A....."
95 SUBURBAN. Not cleaned at all. Bolt it on then go. Dont forget to use the newer fan for the reverse rotation pump.
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
nice!
68cst_ss490
going to run an electric fan, but I guess i need to change my water pump to a reverse rotation one though????
#5 | |
Tim |
Engine and serpentine from '98 Z-71. Since the pic was taken, I replaced the fan shroud with a big-block shroud. Fits like a glove.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
Cadillac power
Blue- Where did you get the upper radiator steel flexi-hose? Or is that just a cover?
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style. --Scott Adams author of Dilbert |
It's a stainless steel one I ordered from Summit. The thermostat housing is of the swivel type with a rubber o-ring so that I could set it anyway I needed. The lower hose is also stainless (you can see it on the left).
I do have a concern about the length of the upper. It's a little on the long side for my taste. Not much more than the rubber that was on the truck the engine came off of. I'll warn you, the rubber ends are a very TIGHT fit. I don't know if Cool-flex would be any better or not, I do know cool-flex costs more, is seamless, and made of brass.
Cadillac power
Thanks! I didn't even hink to look in Summit for stainless hose. I made the one I'm using. Yes, that is exhaust tubing in the middle.
Fabricate till you "puke"
Earl, take a look in my longhorn pics.......there is a shot of a 425 cad. if memory is with me, its a 78 sed devill top hose, & it fit the truck without splicing.... http://community.webshots.com/user/hotrodhorn crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Cadillac power
Thanks for the info. I really need to get a fan cowling in there. I'm afraid if I use that hose, the fan will just chew it up and spit it all over the place.
Upper hose
When I replaced my upper hose for the 350 in my 68 it was slightly to long and had the wrong angle which made a slight kink in it. I then looked at my Camaro and found out the top hose works exactly correct. Order a 78-81 top hose for a camaro with the 350. Wootdog
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
#13 |
I have a question about the serpenten belt set up, can you use a SI-12 alternator or do you have to use another style of alternator from the same year and if so do you have to change the wiring to the newer style alternator, I have already changed over to a internal reg set up. And I think you have to get a long style water pump with revers flow.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect. |
#14 |
68cst_ss490
I got the brakets all cleaned up and I cleaned them with acid. they now are nice and grey, I should have some fresh pics by weeks end. If I feel really ambitous maybe they will end up on the engine, if I want to pull it out of storage
