Old 03-19-2010, 03:46 PM   #1
tucsonjwt
Window regulator roller replacement
My 83 C20 needs the plastic rollers for the power window regulators replaced. They are riveted in place on the end of the regulator arms. Where can I get replacement rollers and how are they replaced? Can you just pry off the plastic roller from the rivet and snap on a new one, or does the rivet have to be drilled out. If the rivet has to come out, how is that removed and replaced?
My AC Delco power window replacement lasted only about 3 years. I think the stuck rollers overheated/overworked the window. I probably have to do both windows.
Thanks.
tucsonjwt is offline   Reply With Quote
Old 03-19-2010, 09:54 PM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Window regulator roller replacement
Drill it out and the new roller comes with a new brad. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 03-19-2010, 10:31 PM   #3
tucsonjwt
So, do you know where I can get this roller and rivet? How do I reinstall the rivet - special tool? Thanks.
Old 03-20-2010, 10:50 AM   #4
mbgmike
We sell replacement rollers. $3.00 each or box of 25 for $25.00.
We sell most all window parts no matter how small.
mbgmike is offline   Reply With Quote
Old 03-20-2010, 12:33 PM   #5
tucsonjwt
Thanks for the information. Do you have any suggestions on how to remove and reinstall the rivet?
Old 03-20-2010, 12:46 PM   #6
mbgmike
Remove just grind off the backside
To install oem style Get big hammer and punch
Or we sell the ones that you can bolt on.
Old 03-20-2010, 02:35 PM   #7
tucsonjwt
Thanks. Is it possible to just pry off the nylon wheel and replace it? There seems to be enough wiggle room between the metal ball end of the rivet and the inside of the nylon wheel to pry it off, but I am reluctant to experiment without a replacement handy. I see that the nylon wheels are sold separately for some GM vehicles - so that got me thinking that I might be able to leave the rivet in place.
Old 03-20-2010, 04:07 PM   #8
mbgmike
Their are wheels for specific vehicles cars and trucks some were two piece and some are one. The ones without a revit are not made to replace the ones using the old revit. They are made to use a new pin , usually plastic.
I am not an expert on all the options out their as these rollers are used by many mfgs through the years and their are all kinds of rollers. It may fit and work well, i don't know for sure. Ford did have a better idea on theirs with the c-clip to make replacement easier.
Old 03-20-2010, 06:04 PM   #9
tucsonjwt
How can I order a box of 25 pieces for $25 from your website? I don't see a listing there. I think I will just get a handful and start to experiment. Thanks.
Old 03-20-2010, 06:43 PM   #10
mbgmike
We have not listed them on the site. We offer too many parts to get them all on there. We really need to split up and have more sites.
You can call the order in on Monday. If you want to buy a few, since your a member I can cut the price to $1.50 each . I assume you want the ones that revit on.
Mike
Old 03-20-2010, 07:52 PM   #11
tucsonjwt
Thanks. I will call the order in Monday and say "Mike sent me"
