Old 03-19-2010, 08:11 PM   #1
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Does a spring go here?
On the Emergency brake aasy. And if so,... anyone have a spare I could buy?
The ratchet has never engaged and now that Im reasymbling the jimmy, its an issue.
Thanx, Tom
Tom Vogel is offline   Reply With Quote
Old 03-19-2010, 08:52 PM   #2
pound41
Re: Does a spring go here?
Yes but all the spring does is snap the handle back in place so the teeth will catch. Just like if you push the lever back with your hand the ratchet should lock where ever you push the pedal to. I am only saying this because you say the ratchet never worked. My 71 blazers spring is broke. I use the emergency brake. I just push the lever back in after I disengage it.
pound41 is offline   Reply With Quote
Old 03-21-2010, 08:57 PM   #3
Longblock
Longblock's Avatar
any hardware/ auto parts spring will work......just take the part w/ you...
Longblock is offline   Reply With Quote
