Old 02-04-2003, 10:41 PM   #1
lotik
drag it like you stole it
My Body Drop And Bag Pics
what you've all been waiting for. hehe
negative camber //LA\\
lotik is offline   Reply With Quote
Old 02-04-2003, 10:42 PM   #2
lotik
dghdf
Old 02-04-2003, 10:43 PM   #3
lotik
asdfa
Old 02-04-2003, 10:44 PM   #4
lotik
gfjkg
Old 02-04-2003, 10:45 PM   #5
lotik
that one was kind of small but its self explanatory.. raise flor same amount has bodydrop.
Old 02-04-2003, 10:46 PM   #6
lotik
dfghdf
Old 02-04-2003, 10:48 PM   #7
lotik
this is just a pic of how i modified my control arms. reson one is because i have the biggest slam specialties bag up front as well as out back. reson two is because it is angled and it corrected the lean the bag had.
Old 02-04-2003, 10:58 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is that what they refer to as a stock floor bodydrop???? That the only time i have seen the frame cut like that. Looka bad a$$ THATS FOR SURE!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-04-2003, 11:12 PM   #9
lotik
you are correct
Old 02-05-2003, 12:18 AM   #10
crazy longhorn
Fabricate till you "puke"
Thats interesting! The old method (channeling) definately takes some room out of the cab. did you have any clearance issues with the drive shaft, or was there a little spot removed farther back(after the trans tunnel)?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-05-2003, 12:34 AM   #11
ol skool 68
turnin wrenches
ol skool 68's Avatar
hey lotik...do you have pics of what it looks like now??? i am assuming that you have got the body back on it?? or any updated pics you might have! BTW the work you did on the frame is awesome!!
"three can keep a secret if two are dead" -unknown hell's angel-
D.M.C. -FF-
68 SWB full frame off (project ol skool)
2000 s-10 formally bagged but now my daily driver...
ol skool 68 is offline   Reply With Quote
Old 02-05-2003, 05:43 PM   #12
lotik
the floor was removed from the trans back to provide drive shaft clearance. i will take some new pics of it in its latest form.
Old 02-05-2003, 05:56 PM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Wow, that obviously has been very time and talent intensive!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-05-2003, 06:00 PM   #14
Dandeluxe
Dandeluxe's Avatar
LOWER
LOTIK, WOW!!!!!!!! HOW LOW CAN U GO!!???? DAN
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 02-05-2003, 06:36 PM   #15
1971Stepside
Almost Satisfied
1971Stepside's Avatar
LOTIK, first off let me say...WOW! I truely admire the amount of thought and work that has gone into your truck.
I have a question about the braces on your rearend bag setup. Do you plan to leave the welds looking, well, rough? Or are you gonna go back and clean things up and make them pretty once you have a good fit on everything?
Keep it goin....looks good.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-05-2003, 07:39 PM   #16
>X<
registered IWATA user
>X<'s Avatar
dude, that is sweet. all you bag guys are making me lean more and more toward bags. if you ever need a hand putting body on or something let me know, i would gladly help
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 02-05-2003, 08:08 PM   #17
Reumster
L.E.D. Freak
Reumster's Avatar
lotik will the bags in the rear that close together make body roll a issue? I mean I'd think the bags that close together would make cornering worse than having the bags farther apart? Them are huge bags though! How much travel/lift will you have ? Why did you deside to go with bags that big? Is it over kill? They'll take more time to fill. What size line are you going to run? It looks like 1/4" line on there? But them huge bags might make it look like that! LOL 3/8"??
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 02-05-2003, 09:57 PM   #18
lotik
hrmm... where should i start? the welds on the back are mine.. heh. i am not a welder. since then someone else has welded it. i will post a pic of how low it is. the line in that pic was temporary. it is no plumbed with 1/2" line and 1/2" valves. hops in the front.
now, i need to vent. i was letting the truck down with a jack earlier in the front. the back was already on a jack with a block on it. as i was letting the front down the back fell off the jack and my roll pan fell right on top of it. bent the hell out of the roll pan and it cracked where i molded it in. i beat it out some but i cant get it real straight now. =( so i stopped messing with it for the day and will look at it again tomorrow.
Old 02-05-2003, 10:47 PM   #19
FRENCHBLUE72
PROJECT 7DEUCE
So whens this thing gonna grace the cover of STREET TRUCKS MAGIZNE!!!!!!!!!!!!
MEMBER #6377
Project "7DEUCE"
Old 03-03-2003, 09:20 PM   #20
XXL
Seņor Member
XXL's Avatar
Lotik, questions for you...
When are we going to see more pics??
Also, what size wheel/tire are you using and what kind of clearances do you have under the step fender when dropped? Bed side, fender side, and top. I've got 255/50/17's on 17x8 with 5 1/4 backspacing and my tires are pushing on the top outer edge of the fender when dropped. I'm sure yours can go much lower than mine so I'm wondering how you solved the problem.
Also looking to see your hood hinge solution pics. I think I saw one pic before but don't recall any mods made to the fenders themselves yet.
Thanks in advance,
Kenneth
XXL is offline   Reply With Quote
Old 03-04-2003, 12:42 AM   #21
Gee_Emm
Thats pretty cool, I would just have a blast engineering the whole thing figuring out how to make things work, oh well one day.
As for your welding career, here is a tip to help you out, make sure the two pieces of metal you are joining are clean down to bare metal.
Oh yah, one question, are you going to leave those pieces of the frame sticking through the floor of the cab, can't they be angled or something? I see a potenial problem for your gas pedal foot resting area.
Gee_Emm is offline   Reply With Quote
