Old 03-19-2010, 11:03 PM   #1
G-Ring
G-Ring's Avatar
Seat Belt interchange
Hey, Was wanting to replace seat belts in my 79 C10. Couldn't find decent ones at pic-a-part but did notice late 80's suburban rear 3pt belts looked similar. Has anyone swapped these with success or had good results with something else?
79' Big Ten
70' 1 ton 4x4 LB "Mean Green"
70' SWB "Major Project"
69' El Camino "t-boned by Camry"
G-Ring is offline   Reply With Quote
Old 03-20-2010, 10:34 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Seat Belt interchange
Good question. I need belts too.
Next time I can get to the wrecking yard I will pull out a set of Suburban rear belts and see if they fit a truck. Good chance they are the same or close enough to work and will probably have much less wear on them vs. a set of front belts.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-20-2010, 12:44 PM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I have wondered if the belts from the 88-98 would fit. I want seat belts with only 1 retractor so I can put the kids car seats in. Do the Suburban rear belts have only 1 retractor?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-22-2010, 12:09 PM   #4
68 TT
68 TT's Avatar
My co-worker with a 90 Suburban says the outer two rear seat belts have single point retractors and work right with car seats. The middle seat belt in the back is just a fixed position lap belt.
