Old 03-20-2010, 09:20 AM   #1
Saddle Houndstooth Bucket Covers
These were custom made by C.A.R.S. before repros came out.They are top quality.Plans have changed and the truck I had these made for is gone.They are in the plastic and clean.Only taked out for pictures.
71-72 style...$300 shipped,payable by postal money order.
Old 03-20-2010, 02:46 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Saddle Houndstooth Bucket Covers
Intrested, do you think a rear seat cover (blazer) could be scrounged up from a vendor? Any ideas...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-20-2010, 08:34 PM   #3
I believe so.I say this because a friend with a Suburban had a buddy bucket custom covered using houndstooth to match a rear seat cover he bought.I`ll give him a call and see what the deal is.
Old 03-21-2010, 07:19 AM   #4
I confirmed the Blazer/Suburban seat covers are readily available from any dealer.Only the buddy bucket covers were custom.He got his from Frank out in WA,I believe he said.It`s a PUI cover.
Old 03-21-2010, 10:08 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Tim - PM 'd you.
Old 03-21-2010, 11:42 PM   #6
f.monroe
f.monroe's Avatar
Have any of you modified 73 and up seats to accept these 71-72 style seat covers ? I like the look of those much better than the 77 seats .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-22-2010, 01:57 AM   #7
67/72junkie
very easy.if you are putting them in 73 up all you will need to do is match the bottom cover.to the 73 up style. the frame on 69 thru 72 runs flat on the bottom.the 73 up frame runs flat for about 4 inches on each side and then tapers up about 1 1/2" to the rear.if you remove the 73 up seat cover and lay it next to the 72 style you will see exactly what I mean.you only have to unstich a small section of the wire holder that the hog rings attach to. trim the material to match the taper of the 73 stlye and restich the wire holder.all that is necessary to put the upper cover on is to add foam at the top to match the 72 style foam.I can take some pick of each tomorrow and show you the differances.If you want to make 73 up seats match correct 72 style you have to weld a pie shaped piece to the lower skirt to make the lower skirt flat across and then the 72 cover fits correct.the frames are the same.the only differance is the lower skirt and the upper foam.even 77 up high back have the same frame just another bar welded across the top and differant upper foam.
67/72junkie is offline   Reply With Quote
Old 03-22-2010, 08:32 PM   #8
olblue60@aol.com
member
Monroe
Or you can purchase a new pair of seatback foams. I'm in the process of doing it now
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 05-12-2010, 08:02 AM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Tim, Got the seat covers. They are exactly as described, Really nice quality. I'm looking at a Truck World cover to complement these. I'll let ya know...Nice doing business with you! Thanks David
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 05-12-2010, 08:55 AM   #10
David,I`m glad you like them.As always,I fret a bit until I hear a person is happy with anything I sell.I look at it as if I was the buyer and hope to offer what is expected.I`d like to think any differences in fabric,if any,will be very un-noticeable from front seats to back.Can`t wait to see this Blazer when it`s done!
