02-05-2003, 12:08 AM | #1 |
PROBLEM need advice on oil leak
on my intake manifold I have oil sitting in the gallery were the bolts fasten it to the head the back of the intake seems to be caked with oil.
I have wiped the oil out of the galleries before and it seems to come back after i drive for a while. It seems to me that I need to change out the intake gaskets I also get an oil leak on the ground it does'nt seem to be coming from the rear main because It looked good when I had the tranny rebuilt I think it is coming out the back of the intake. any suggestions |
02-05-2003, 12:19 AM | #2 |
FixerUpper
Valve cover maybe ?or the back of the intake I guess like you said
1-Cheyenne 72 700R4,camper special all original when i got it then i improved it a little Blue and White 3.73,4 core rad, 700r4,MSD hei ,turbo muffs dual exhaust only had 50 k on it when i bought original mile sweet old ladies truck turned into a stump puller No. 2 C-10 72 w/air and Tilt and power and the cheyenne trim package shtbd is dropped 2-3w/factory tilt has torq thrust 2 rims 2003 dodge neon steel blue color |
02-05-2003, 12:28 AM | #3 |
the leak out the back was the d side valvecover gasket I just replaced I didn't tighten it down good enough
But the oil on top of the intake by the bolts if from something else must be the intake gasket on that side. |
02-05-2003, 12:30 AM | #4 |
i dunno how to help ya but my friend and i had a scare, we put a quart of oil in the pass. side valve cover and heard a "drip, drip" looked down and most if not all of the oil was on the ground, we thought there was a hole in his engine, but come to find out htere is a chunk of valve cover gasket missing.haha
kevin
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
02-05-2003, 12:40 AM | #5 |
Fabricate till you "puke"
A leaky valve cover can get oil on top of the intake, but I have also seen oil seep up the threads of the intake bolts( i goop them good with RTV). You might take a mirror & a flash lite & look at the back of the intake(intake to block seal)......I have seen them leak enough there to dripp out the bottom of the bell ( you get that oh chit feeling.....not the main seal!). on the ends of the intake, I toss the rubber seals, & run a bead of high temp RTV. You might also check valve covers as mentioned on the leak on the ground deal......also the oil press sender is in the back & they tend to make a mess when they leak. good luck...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-05-2003, 12:59 AM | #6 |
I'll try gooping the bolts with rtv
02-05-2003, 02:28 AM | #7 |
go bucks!
the center bolts on most all sml.blks. leak onto the intake manifold .whats happenin' is the oil is backing up the threads.doesn't usually hapen to the outer bolts in either the front or the rear as often.don't use a rtv sealant as the excess may and usually does,fall down into the lifter valley and will get into the oil system and plug up the areas that will need it the most.....ie, the main bearings etc........use a thread sealant like bowman's or perma-tex thread sealant.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
02-05-2003, 10:26 AM | #8 |
I miss this truck.
Oil seeping up bolts?
Slap some lock-tight on 'em. That way you'll make it harder next time you want to pull the intake off. Maybe that's just my method of mechanicing. hehe
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
02-05-2003, 12:06 PM | #9 |
I have used RTV for yrs on the intake bolts, & the ends.....i have never seen a problem with it getting into the engine. I use the red high temp stuff, & clean the bolt & the hole good....then fill the hole(you will notice that the hole in the intake is larger than the threaded hole in the head by a good amount). When you thread the bolt in, the threads thend to "clean" the bolt of sealer, & most of it will stay in the hole in the intake. what little bit that may get in the into the eng ......wont cause any trouble. In all the things I have tryed, this method has worked best for me. CrazyL
02-05-2003, 12:19 PM | #10 |
I had the EXACT same problem you're having, and it turned out to be oil seeping up around the intake bolt threads. Turns out two of the intake bolts were barely finger tight when I went to pull them.
I pulled the entire intake, and used a set of intake bolts from Summit Racing with the 7/16 heads, gaskets from NAPA, and some of the Silicone Sealant I use on my differential housing (Sillicone II Window and Door sealant: black in the blue and gold tube at Home Depot). Worked like a charm. Takes the heat well, and doesn't leak at all. I finished up by pulling the oil pan and replacing it with a new chrome one and a Fel-pro 1 piece (check the Reviews board). Exactly ZERO leaks now.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
02-05-2003, 08:44 PM | #11 |
D.U.F. Member
I use that white PTFE thread sealer from GM on my intake and head bolts. Works good for me.
MEMBER OF THE DISCS UP FRONT CLUB '72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt '68 C-10 4spd (not running) '79 C-10 LWB Mild 350 '80 Caprice Classic, 2-dr '97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto |
