Old 03-20-2010, 12:13 PM   #1
bmacdona
'51 new IFS installation
My first real post, I'm pretty excited about the new front suspension kit I put into my truck over the past couple of weeks. My truck had an old, worn out Pacer suspension. While looking at all the Mustang II options, I found Flat Out Engineering's Corvette IFS kit. With a LOT of help from a friend, we got this installed early last week.
I've attached a few pictures, I'm really impressed with the kit and hoping that it'll handle as good as it looks. I'm off to Alaska for a month, so I won't be able to get the rest of the truck together until I return.
Thanks for looking!
Brian
bmacdona is offline   Reply With Quote
Old 03-20-2010, 12:51 PM   #2
NONHOG
NONHOG's Avatar
Re: '51 new IFS installation
Dang ! Looks like a 1/3 of the weight. And nice looking too !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-20-2010, 12:59 PM   #3
blitz'd
vintage car junkie
blitz'd's Avatar
Looks much better, that front end looks really wide though. Are the tire going to clear the fenders?
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 03-20-2010, 01:06 PM   #4
bmacdona
Thanks! I think it looks great!
The Pacer front end had a track width of 61 inches, the Vette is 59 1/2, so the fenders shouldn't be a problem.
Old 03-20-2010, 05:15 PM   #5
entourageguy
Yellow truck club
entourageguy's Avatar
looks like a nice clean setup ....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-20-2010, 10:46 PM   #6
solidaxel
solidaxel's Avatar
How about the offset of the front wheels, what size tire and wheel will you be using
what is the finished cost of parts x-member and replacement bearings bushings shocke coilovers ball joints and R&P ?
Will the motor mounts and headers clear everything, how many u-joints in the steering shaft. Is the Corvette the same track width as the AD. Does the bottom Arm bushing line up with the piviot on the tie rod of the R&P (bump steer)
We are getting ready to put a front end on the extended cab project and I like Aluminum Arms. and Rob has some nice equiptment !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-21-2010, 08:18 AM   #7
entourageguy
Yellow truck club
Man you ask alot of questions ....
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-21-2010, 09:49 AM   #8
ratty 46
Yes lots of GOOD questions .....
RAtty 46
ratty 46 is offline   Reply With Quote
Old 03-21-2010, 10:25 AM   #9
solidaxel
solidaxel's Avatar
I was hoping Brian colud answer a few of these as he is not selling these and would have a 1st person experience !!
I haven't purchased the next front suspension yet, and I have a few days to do some "homework".
I haven't used coilovers so I don't know the cost or how they ride on our pot hole streets!!!
LS 3 4L70E
Old 03-21-2010, 10:33 AM   #10
BigSix302
BigSix302's Avatar
Nice looking setup! I have a Pacer I am installing soon. You want to part with any of the old parts?
AD's Rule!! 53 GMC Suburban--48 GMC 1/2 Ton project--49 Chevy Pick-up--52 Chevy Pick-up (my driver)
BigSix302 is offline   Reply With Quote
Old 03-21-2010, 11:55 AM   #11
bmacdona
I don't have the receipts close by, but, these should be pretty close:
Donor Corvette suspension $500 (control arms, spindles, R&P, etc)
IFS kit from Flat Out was $795
Shocks were an additional $399
Urethane bushings, ball joints, etc (IIRC) approx $375
New motor mounts - $125
The motor mounts will install just behind the X-member (you can see the masked off portion on the frame in the attached pic).
I didn't have time to get the steering installed, I'm hoping to get away with 2 u-joints. The rack lines up pretty well (again, in the attached pic).
Track width for the AD is 59.5, on the '86 Vette it's 59.6
No decision yet on final tire size, what's on the truck now are 225/60-15's on the front, 225/75-15's on the rear
Old 03-21-2010, 11:59 AM   #12
bmacdona
The Pacer pieces are long gone, I'm afraid....Sorry.
Old 03-21-2010, 12:20 PM   #13
bmacdona
I'd be glad to answer any questions I can, however, I've not a lot of experience, this is/was my first big mod to anything. (that's why I'm so happy with the way it turned out).
I decided to go with the corvette front suspension rather than a mustang ii because:
A. it was a bit different
B. the initial cost seemed to be (surprisingly) a bit cheaper than the US made MII kits.
Flat Out and Progressive Automotive both make Corvette IFS kits, the major difference being that Flat Out requires a bit less welding and allows you to use the stock Corvette rack, where Progressive requires a shortened rack. I have no doubt that the Progressive kit is of similar quality.
Old 03-21-2010, 01:07 PM   #14
entourageguy
Yellow truck club
Man that front end setup looks nice and clean.
The coil overs work great. I had them in the front of my truck for the first 6 years. Found the coils like to settle in and you have to adjust them. They were finally bottoming out end of last year and I replaces them with a set of shock waves.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-21-2010, 01:15 PM   #15
Kabwe
Certified Car Nut
Kabwe's Avatar
The IFS looks great.
Kabwe is offline   Reply With Quote
Old 03-21-2010, 09:44 PM   #16
solidaxel
solidaxel's Avatar
Thank You for answering my questions. Keep us posted on your build and any surprises !!
Did you not have to replace the rack from the donor, do you know how much a rebuilt Corvette rack goes for
LS 3 4L70E
Old 03-21-2010, 09:59 PM   #17
mobileortho
mobileortho's Avatar
Awesome looking setup. Clean & simple.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 03-22-2010, 10:19 AM   #18
bmacdona
The Corvette ifs (including the rack) had been recently rebuilt by the previous owner.
A new rack is available from Flat Out for around $500. I've seen rebuilt ones advertised for around $250.
Old 08-30-2010, 09:06 PM   #19
blu52
any progress? I have a front and rear kit from flat out waiting in the garage. What are the part numbers for the front coilovers?
thanks
Rafael
blu52 is offline   Reply With Quote
Old 08-30-2010, 11:20 PM   #20
Coronas56
Coronas56's Avatar
Nice..The motor will sit higher due to the rack ......I made custom motor mounts for mine.
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 08-31-2010, 05:11 AM   #21
bmacdona
The truck is back together and (as coronas56 mentions) I ended up having to fab some motor mounts due to the rack height. I'm not sure of the p/n for the Aldan shocks, I bought them with the kit from Flat Out (p/n 7000).
The end result was great! the suspension is everything that I expected, I only wish that I'd gone with the IRS as well, although, I'd rather be driving it than working on it! I'll get some pictures in the next day or so and post the end result.
Old 08-31-2010, 06:03 AM   #22
55dude
55dude's Avatar
sure cleaned things up quite a bit! reminds me when i remove a incorrectly installed corvair front end from a 51' panel some 30 years ago. nice upgrade even if it was a few bucks.
55dude is offline   Reply With Quote
Old 08-31-2010, 08:50 AM   #23
solidaxel
solidaxel's Avatar
That is what they taught me in Kitchener-Waterloo back in 1945 !!!
LS 3 4L70E
Old 08-31-2010, 09:38 AM   #24
Gabbyp
Bigsix302 sent you a PM about Pacer parts
Gabbyp is offline   Reply With Quote
Old 08-31-2010, 10:10 PM   #25
bmacdona
Here's a couple of pix to show the final stance of the truck and to try to show the clearance on the fenders (questioned earlier).
Sorry about the quality, but it's a nasty day in Olympia and I'm off to Alaska for a month.
