Old 03-20-2010, 12:15 PM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Ford 9" Conversion
I am debating on doing a Ford 9 inch conversion. I have tried to search for a thread and have not found a good one yet. I am basically wondering if there is a better year of truck to pull them from and also any other tips and tricks.
chevyguy_72 is offline   Reply With Quote
Old 03-20-2010, 12:19 PM   #2
fleetimus
fleetimus's Avatar
Re: Ford 9" Conversion
I used a 9" out of a full size Lincoln. Easy swap and it is only 1" wider than my 68 rear end. The stock e-brake cables worked!!
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 03-20-2010, 12:24 PM   #3
chevyguy_72
Vintage Evil
Did you weld on all of the mounts or did you use a kit of some sort? I could use the inch of width...
Old 03-20-2010, 12:37 PM   #4
fleetimus
fleetimus's Avatar
I removed all of the Ford brackets and welded on the mounts from early Classics. Also got their Panhard kit.
Old 03-20-2010, 12:40 PM   #5
chevyguy_72
Vintage Evil
Are those the lincoln disc brakes?
Old 03-20-2010, 12:42 PM   #6
fleetimus
fleetimus's Avatar
Complete rear end from a Lincoln. T-birds also had reae discs. They are 70s vintage.
Old 03-20-2010, 12:45 PM   #7
chevyguy_72
Vintage Evil
So did you buy different rear wheels or did you redrill the axles?
Old 03-20-2010, 12:48 PM   #8
fleetimus
fleetimus's Avatar
Full size Ford cars are 5x5 bolt pattern. Same as the 71? and up Chevy trucks.
Old 03-20-2010, 12:51 PM   #9
chevyguy_72
Vintage Evil
Got ya...Thanks for the info
Any one else?
Old 03-20-2010, 01:18 PM   #10
SOON2BLAZE
SOON2BLAZE's Avatar
here ya go :http://67-72chevytrucks.com/vboard/s...d.php?t=392566 other things to think about, E cable, driveshaft length, u joint that fits what ever pinion yolk comes with the 9". Mine is from a 75 versailles. As stated above, chop the ford brackets (save e brake cable hole)Set your pinion angle and get some early classic saddles and panhard bar/ mount.
SOON2BLAZE is offline   Reply With Quote
Old 03-20-2010, 04:44 PM   #11
chevyguy_72
Vintage Evil
Looked on early classics site and could not find a link to the brackets... Anyone have one?
Old 03-20-2010, 04:56 PM   #12
John Fabris
TOTY 2006
John Fabris's Avatar
Did the same thing for my rear nine as fleetimus. Mine came from a 75 lincoln with a 460 motor.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-20-2010, 05:33 PM   #13
chevyguy_72
Vintage Evil
How much is a fair price (ballpark) for a Lincoln disc brake rear end?
Old 03-20-2010, 06:34 PM   #14
lewisaric
lewisaric's Avatar
I would like to know more about this also
lewisaric is offline   Reply With Quote
Old 03-20-2010, 06:57 PM   #15
fleetimus
fleetimus's Avatar
http://www.earlyclassic.com/catalog.aspx
Type in "rear axle saddles" under keywords
Old 03-20-2010, 07:23 PM   #16
chevyguy_72
Vintage Evil
got it... thanks
Old 03-20-2010, 09:52 PM   #17
chevyguy_72
Vintage Evil
Anyone else?
Old 03-21-2010, 06:31 AM   #18
lewisaric
lewisaric's Avatar
What newer 9inches will work that already have disk brakes.
Old 03-21-2010, 06:37 AM   #19
lewisaric
lewisaric's Avatar
I was just wondering cause mid 70`s lincolns are not that common around here
Old 03-21-2010, 11:11 AM   #20
fleetimus
fleetimus's Avatar
Lincolns and T-birds had the rear disc. Have a salvage yard do a search. I believe the Versaille and Granada rear ends are too narrow. Expect to pay from $150.00 to $ 500.00.
Old 03-21-2010, 12:45 PM   #21
Leadfoot
How narrow? If you want to put a nice wide wheel with a big lip, these might be nice! Obviously you have to buy new wheels, but who doesnt want to? (want to and can afford to, always the big issue)
Leadfoot is offline   Reply With Quote
Old 03-21-2010, 02:35 PM   #22
fleetimus
fleetimus's Avatar
I have 15x10 on mine. No problem.
Old 03-22-2010, 09:56 AM   #23
bobshotrodblazer
BigBlockBobby
What gear ratio comes in the those lincoln rears?
Bob
bobshotrodblazer is offline   Reply With Quote
Old 03-22-2010, 11:00 AM   #24
John Fabris
TOTY 2006
Not sure on all of the ratios, but for mine, from a 75 lincoln with a 460, it has 300.
John Fabris
67 C10 SWB
Old 03-22-2010, 04:02 PM   #25
fleetimus
fleetimus's Avatar
Ford 9" has a lot of options for ratios. Mine was a 2.73 and I switched it to 3.25.
