03-20-2010, 12:53 PM | #1 |
86 Silverado
I just bought an 86 silverado.the po said it was leaking water that was the reason for parking it.I found it was the freeze plug by the flywheel was bad it sit for 6 years.I got it to start up had to change the computerise dist. for a reg one.It sounds great but when I put in gear it acts like something is holding it back.I check all the wheels and they spin freely so i knows its not the brakes being locked up.The transmission has a wire plug on it. What is this for and can I by pass it?
77 swb starting all over again. Last edited by boogie67; 03-20-2010 at 12:54 PM. |
03-20-2010, 02:49 PM | #2 | |
Conversion Truck Addicted
Re: 86 Silverado
Auto or Stick shift?
Thomas Quote:
03-20-2010, 04:05 PM | #3 |
Re: 86 Silverado
Its an auto.Hell I did not want to take pics Its ugly but I only paid $100 for it.Motor sounds great for setting so long.
77 swb starting all over again. Last edited by boogie67; 03-20-2010 at 04:05 PM. |
03-20-2010, 08:02 PM | #4 |
STILL PLAYS WITH TRUX
Re: 86 Silverado
Try removing the catalytic converter and see if she will run i bet it's pluged up!
And need pic's of this odd plug on the trany. BTW Thats a killer $100 truck! Last edited by 87 STEPPER; 03-20-2010 at 08:03 PM. |
03-20-2010, 08:57 PM | #5 |
Re: 86 Silverado
Its just a 2 prong plug on the pass. side of trans right under the trans lines.Yeah I got lucky.I was passing by and saw him pulling it out.I asked him if wanted to sell it.He said he was about to sell it the local upull em for $100.I bought it and a good water cooler for a$110.
77 swb starting all over again. |
03-20-2010, 09:31 PM | #6 | |
Re: 86 Silverado
03-21-2010, 12:01 AM | #7 |
Re: 86 Silverado
the wires are for the lock-up torque converter. it will kick your truck down a couple hundred rpms when your cruising to try to get better wpm. it hooks to a vacuum switch on the firewall by the master cylinder. do you need it hooked up? no. you probly wont notice a difference. will it hurt the trans? im not sure but ive been running mine without it hooked up forever and it seems fine. i say if you have the switch, then hook it up.
"I'll keep my guns, money, and freedom. You can keep the "change" |
03-21-2010, 05:30 AM | #8 | |
Re: 86 Silverado
for 100 bucks dont complain or else give it to me lol
Thomas Quote:
03-21-2010, 09:55 AM | #9 |
Re: 86 Silverado
Can't complain,; it a chevyThis one has no rust issues at all ,very clean cab.
If I get this one going I may sale the 69.i just need a truck.I got alot of work to do around the house.
77 swb starting all over again. Last edited by boogie67; 03-21-2010 at 09:56 AM. |
