03-20-2010, 04:32 PM | #1 |
Smog Pump Removal
Hello Everyone! I am removing the smog pump from my 5.7l. It is not hooked up and not required in my state of residence. Can anyone tell me what to do about the openings in the exhaust manifolds and the sensor to the smog pump? I thought about replacing the manifolds with ones that do not have the smog access. Any suggestions would be greatly appreciated.
03-20-2010, 07:56 PM | #2 |
STILL PLAYS WITH TRUX
Re: Smog Pump Removal
What year is the truck?
You have 3 options on the exhaust 1 go to home depot and buy plugs to cap off the ports. 2 buy a set of headers. 3 buy a stock set of non air injection manifolds. Id go with #2.........Actually i did! lol Im trying to think of what sensor your talkin about i dont remember there being one. |
03-20-2010, 09:13 PM | #3 |
the pollock
#2 is the coolest option..
my truck at one point intime had smog during the rebuild i removed everything related to it, pump was allready gone, then i also did headers. which now just is ... well it's awesome! hahaha
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
03-21-2010, 03:36 AM | #4 | |
haha, ford guys...
the tube off the headers/manifolds is introduced into the air pump, egr, carb. this is what i did: 2.00 usd No tubes comming off headers at flange Last edited by spinem; 03-21-2010 at 07:51 PM. |
03-21-2010, 12:46 PM | #5 |
the pollock
hey those are some sexy valve covers where did you get them?
03-21-2010, 07:49 PM | #6 |
haha, ford guys...
04-13-2010, 05:35 AM | #7 |
Sorry it took me so long to reply. Been working ot and falling behind on my honey do list. My truck is a 87 silverado r10 lwb 5.7l tbi. I have recently come across another 5.7l tbi from a 92 chevy 4x4. The manifolds on this one doesn't have the smog ports on them. Think I will swap them out. Here are some pics of the ones with the smog.
04-13-2010, 05:40 AM | #8 | |
Conversion Truck Addicted
is the sensor you talking about the O2 Senser? has mostly a 4 wire plug
Thomas Quote:
04-13-2010, 10:54 AM | #9 |
As far as the smog tubes go, cut the metal tube off from the nut that threads into the manifold. Remove said nut from manifold and weld the tube hole shut. Re-install the now closed threaded nut.
04-13-2010, 02:26 PM | #10 |
haha, ford guys...
04-13-2010, 05:18 PM | #11 |
You could even weld the nuts shut while still attached to the manifolds in the vehicle if you felt like it. Would make the job a little harder but is possible. Than remove any associated components that the tubes are attached to.
04-13-2010, 07:44 PM | #12 | ||
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
04-14-2010, 05:59 AM | #13 |
Thanks for the info. The plug idea sounds less time consuming. I'll let you guys know how it goes.
04-14-2010, 06:05 AM | #14 |
Old Heap Driver
............and find a suitable sized box to keep and store all the smog stuff you remove. Needing all that $%#! to meet "new" smog regulations one day will make that box a welcome sight. LOL.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
04-14-2010, 10:54 AM | #15 | |
04-14-2010, 12:44 PM | #16 | |
EDIT: Oh wow, that one does only have one tube on it. When did GM go to that style? Mine had 4 smaller ones and some were very testy to unscrew.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 04-14-2010 at 12:52 PM. |
04-14-2010, 05:16 PM | #17 | |
04-26-2010, 10:20 PM | #18 |
The plug idea worked great. I had the existing bolts tapped and purchased the plugs for $1.50. Thanks for the great idea. This will hold me until I can purchase some headers and new exhaust system. Here are some pics of the plugs.
