Old 03-20-2010, 08:07 PM   #1
easyrider
easyrider's Avatar
67 air conditioner problems
I am having problems with my a/c. The clutch isn't engaging when I turn on a/c fan. I know on the 67 you have to put the lever on a/c and on cold and then turn on the fan to make it come on. The fan comes on. With all that done, clutch still doesn't engage. I made sure the fuse was good and that the plug on the compressor was plugged in good. I have a relay in the circuit and there is the fan switch itself. Any suggestions as to where to start the tracing process? What is the most likely thing to go wrong. I had the a/c serviced last summer and the truck has set in the shop all winter. Yesterday was the first time that I tried to use the a/c and found that it didn't work. Any suggestions would be appreciated. Thanks
easyrider is offline   Reply With Quote
Old 03-20-2010, 08:11 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 67 air conditioner problems
It sounds like it is low on charge.
Mine did the same thing and I charged more freon in it and it now works.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-20-2010, 10:42 PM   #3
caja_larga
I would guess low charge.
caja_larga is offline   Reply With Quote
Old 03-20-2010, 11:21 PM   #4
hayhauler71
hayhauler71's Avatar
Do you have power to the ac clutch. Does the clutch engage.
hayhauler71 is offline   Reply With Quote
Old 03-21-2010, 12:01 AM   #5
easyrider
easyrider's Avatar
I haven't jumped the clutch power to see if it will engage or if it is something else besides a power issue.
Old 03-21-2010, 09:31 AM   #6
JimKshortstep4x4
Unless it has been added there is not a low pressure switch on the compressor. I would suggest using a jumper wire to the compressor, (positive side) to see if the clutch will pull in, engine off).
Here is a diagram of the wiring on the AC. (I have not seen trucks with the anti-dieseling relay so yours probably does not have one).
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
