Old 03-20-2010, 09:02 PM   #1
flips72
flips72's Avatar
big back glass conversion
just wondering if anyone has changed their cab from small rear glass to the big glass using their cab. cant seem to find any threads on this, any help would be appreciated.
flips72 is offline   Reply With Quote
Old 03-20-2010, 09:04 PM   #2
magooster
'65 GMC Project
magooster's Avatar
Re: big back glass conversion
I planned on doing this until I bought a BBW donor cab.
http://www.classictrucks.com/tech/cl...all/index.html
Beauty is in the eye of the beer holder
1965 GMC project
1999 GMC Safari (daily driver)
2005 Scion XB (Wifey's car)
magooster is offline   Reply With Quote
Old 03-20-2010, 09:24 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I cut a BBW out of a scrap cab using a hook knife and hammer. It split the welds quite nicely. Did not have to remove the roof panel. Talking to another member, his buddy had simply used panel adhesive to glue his BBW metal inplace, then was T boned in an accident and the truck was destroyed but the panel adhesive held. If I remember correctly he used the panel adhesive through the roof section and spot welded the glass contour opening and along the door openings. There are members who spoke of welding the seam along the roof section from the inside and described how hard it was to finish the joint so that it looked good.
Old 03-20-2010, 09:47 PM   #4
K-TEN
I had it done. I had a donor big back window truck. My body guy drilled out th spots and then, as Aerotruk has said, panel adhesive was used for the reinstall. No roof removal was necessary. Once the inner piece was in place, the outer piece was cut to the proper dimension of the inner piece. All painted up and pretty.
K-TEN is offline   Reply With Quote
Old 03-20-2010, 10:10 PM   #5
Slow Build
Slow Build's Avatar
Mine was done by the PO. Luckily, I guess he did it right since I'm the one that put the window in after he did the work. I know he didn't remove the roof either. It's solid and you can't tell that it hasn't always been there.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-20-2010, 10:22 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Here's a magazine feature on how they did the conversion:
Old 03-20-2010, 10:46 PM   #7
flips72
flips72's Avatar
appreciate the info,now just finding a donor cab to get the inner panel out of. as far as the panel adhesive i have a friend in the auto body buisness and he swares by the 3m product.thanks again.
Old 03-21-2010, 01:08 AM   #8
magooster
'65 GMC Project
magooster's Avatar
I already posted that link in post #2 ↑↑
1965 GMC project
Old 03-21-2010, 01:25 AM   #9
JRBECK64
Frizzle Fry cut the top off my 60 big window cab so he might have some insight on how to do this. Not sure if he has done it yet. Be worth asking.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 03-21-2010, 04:37 AM   #10
Frizzle Fry
Frizzle Fry's Avatar
I prefer the looks of the panel swap as opposed to the way they did "project old school." The "real" inner panels have an inset next to the window opening pinch welds (similar to the outside) so the rubber doesn't stick out as much. Gives it a more finished look
...no I have not done mine yet but I have the panel, rubber, and glass ready to go! I will be doing it as aerotruk63 described.
Frizzle Fry is offline   Reply With Quote
Old 03-21-2010, 10:00 AM   #11
1968vetL-71
Junior Member
1968vetL-71's Avatar
I seen your in Tennessee , there is a BBW cab in the u-pull it junk yard in Nashville. Glass is there and all. You can buy the whole cab, but it's very very rusty! But you can just buy the stuff you need. It's cheap.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 03-21-2010, 06:09 PM   #12
64c20crewcab
64c20crewcab's Avatar
Here is the setup I thought bout using for swapping out the rear window in my crew cab...http://www.classicbigwindow.com/
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 03-23-2010, 09:49 PM   #13
flips72
flips72's Avatar
lord willing,headed to nashville saturday morning. thanks again.
Old 03-24-2010, 01:29 AM   #14
collins10672
collins10672's Avatar
i have never done this conversion myself,but i have seen it done and it looked 100% original.it was done the way aerotruck described.panel adhesive for top joint and everything else welded back like original.good luck.
collins10672 is offline   Reply With Quote
Old 03-27-2010, 03:23 PM   #15
flips72
flips72's Avatar
just got back from nashville..scored cab with good inner panel, and a good big glass for 146.00,thanks again. special thank you to 1968vetl-71 for the pull-a-part info.
Old 03-28-2010, 12:00 AM   #16
collins10672
i know what you mean about those pull a part deals.i found a perfect 64-66 roof last summer in knoxville,but i didn't have a saw with me lol.good score on your cab panels.
Old 03-28-2010, 10:01 AM   #17
1968vetL-71
Junior Member
No prob flips! Glad too help. I was going to cut out the floor hump ( it's very nice ) but I decided to try to find a high hump instead.
Old 03-28-2010, 07:44 PM   #18
flips72
flips72's Avatar
if you need this one you are welcome to it. are you planning on going to the april rod run in pigeon forge, if so i will cut it out and bring it with me. we are coming up for the day on saturday. no charge.
Old 03-28-2010, 08:13 PM   #19
flips72
flips72's Avatar
it also has a pretty nice roof if someone needs it.
Old 04-08-2010, 12:06 PM   #20
jac70ss
Question Re: big back glass conversion
Interestingly, I too bought a bbw cab from Pull a Part in Memphis. I'm a little confused by the comments regarding "roof section". after looking at my cab, was going to remove the inner panel as follows:
separate spot welds around back glass.
" " at base of panel behind gas tank
" " around door openings
" " across top of windshield pinch weld.
I was most likely going to use the adhesive as well around back glass, front windshield. will weld around door and lower rear of panel. Is there a roof section i'm overlooking?
jac70ss is offline   Reply With Quote
Old 04-08-2010, 12:55 PM   #21
Frizzle Fry
Going from small to big you don't have to bother seperating the spot welds along the old window pinch. Just slice it outside the welds. Later you will trim the outer opening to match the big inner.
Instead of taking the whole roof panel out, what I've seen done and plan to do is slice the old inner panel just behind the upper/rear seam. Then clean up the flange on the remaining inner roof panel. This is the seam location where panel ashesive is used for the new back panel.
Around the doors (rear section only) and behind the gas tank are the areas where spot welds need to be sperated.
Old 04-08-2010, 02:58 PM   #22
jac70ss
So you don't take the entire inner panel out, only the rear half. Makes sense and saves time too i would imagine.
Old 04-09-2010, 05:00 PM   #23
flips72
flips72's Avatar
just got my inner panel out of my truck. i only removed the back half as well. very scary to a novice, turned out it wasnt that bad.i drilled out the spot welds around the doors and back of cab then using a sawsall cut out around back glass, instead of drilling out welds. used a 4 inch grinder with a cut off wheel to trim across inner panel (about a 1/4 inch to the side i removed) then took a pair of side cutters and rolled the metal towards the spot welds, when i came to a weld twist hard and they will break loose then just dress them up with a grinder.
Old 04-09-2010, 05:06 PM   #24
flips72
flips72's Avatar
soon to be bbw
Old 04-09-2010, 05:26 PM   #25
collins10672
looking good,and thats really a nice truck too.post more pic's when you get it finished.
