Old 03-20-2010, 10:09 PM   #1
rain_man
rain_man's Avatar
i need help
ok guys not relly sure what my problem is but i have noticed that my rear driver wheel sets deeper into the fender then the pass side i lowered it a few weeks ago and was pondering maybe lower but it rubs on the pass side any thoughts?
it seems to be allmost a inch different?
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 03-20-2010, 10:37 PM   #2
Nick's81
Nick's81's Avatar
Re: i need help
track bar now to long you'll need to shorten it or get a adjustible 1
Nick's81 is offline   Reply With Quote
Old 03-20-2010, 10:51 PM   #3
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
Re: i need help
Ditto!
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 03-20-2010, 11:03 PM   #4
rain_man
rain_man's Avatar
Re: i need help
were is a good place to pick up a adjustible bar?
is there a way to check to make sure that is the problem before i drop some change on a new part
thanks
NEED A NEW PROJECT
Old 03-20-2010, 11:22 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Re: i need help
thanks
CPP/ Classic Ind / or any of the usual suspects carry the adjustable bars. I would jack up the rear under the trailing arms so as to keep the rear suspension loaded and then break out the tape measure.
.....or jack up the frame and watch how much the rear moves side to side as you pass every 1/2'' or so. Would require 2 jacks.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-20-2010, 11:24 PM   #6
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: i need help
You can run a string down the frame to common points on each side, from front to rear. A one inch bend should be easy to spot, as I think the frames are the same width from front to back. Meaure from the inner wheel or tire to the frame in the rear. Do this on both sides. If the rear end is out and the frame is not bent, then the rear end needs to go over to one side to be re-centered. This is real common on lowered trucks. At stock height, the track bar is on an angle, when you lower it, the bar gets more parallel to the ground. This pushes the rear end over some. I bought mine from Early Classic. There are several companies that make them, I believe. I hope this helps, Jeff.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 03-20-2010, 11:32 PM   #7
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: i need help
I'm with everyone else, Track bar. whenever you lower it with factory pan-hard it will push to one side.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
