Shake and Bake!
![]() Join Date: Feb 2010
Wrong Carb Adapter? PO has me confused on what he did.
Hey guys,
I was doing some work on the truck today and I pulled the carb and adapter plate. Here is the thing, I have a Edelbrock intake, and an Edelbrock carb but I can't find the right gasket for between the intake and spacer. I need to figure out what gasket I need for the adapter plate or if need to run this adapter plate, or a different one, I am lost here. Not sure what the PO did here, or if it is right. Here are some pics of what I have going on: Edelbrock Intake: ![]() Edelbrock Carb: ![]() Spacer: ![]() ![]() Thanks guys, you ![]()
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
72 Chevelle Club
Re: Wrong Carb Adapter? PO has me confused on what he did.
I would say try a stock quadrajet gasket on the intake should work for ya .
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
knuckle buster..
![]() Join Date: Oct 2007
You already have a hi-rise manifold... the spacer isn't doing anything else for you.
You can run a regular four barrel carb gasket for a holley or edelbrock from any parts store. Read this:linky linky
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
72 Chevelle Club
He has a square bore carb and that's a spread bore intake so you can't mount the carb to the intake without a spacer.
#5 | |
knuckle buster..
Good eye Bob.
I really hate wet sanding!
![]() Join Date: Dec 2008
might try this, i used it on my spread bore intake to square bore carb, worked great, only added about 1/4 inch to carb height.
http://www.summitracing.com/parts/SUM-G1420/
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
check out this link , top pic is what you have
Second pic down is an adapter plate, comes with some manifolds new. http://www.edelbrock.com/automotive_..._spacers.shtml You need a quadrajet gasket
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
Shake and Bake!
Hey thanks guys! I went to go pick up a quadrajet gasket and they didn't have any, I'll try Napa tomorrow.
That intake has both bolt patterns. Technically that carb would bolt on without the spacer BUT they tend to have a vacuum leak around the back barrels. If you wanted to do away with the spacer you could run a plate like the one linked below. Since you already have the spacer I would just use it.
You should be able to get a spread bore gasket at NAPA no problem. It does not have to be specifically for a QuadraJet. It can be any aftermarket spread bore gasket. http://www.jegs.com/i/Edelbrock/350/2732/10002/-1 |
i'd take the adapter with me to the parts store and get gaskets that fit each side// or just get a lenth of gasket material and cut out the two gaskets required then you'd have gasket material left over and in stock for the next dilema
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-21-2010 at 11:17 AM. |
![]() Join Date: Sep 2000
Use one of the plates above they will work just fine. And not the one you have it will mise up your fuel air flow and rune an gains from puting on the intake.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#12 | |
![]() ![]() Works on inside and outside edges and those 3/4 inch throttle bores too. |
