03-21-2010, 12:51 AM | #1 |
do carb spacers really work?
I have an Edelbrock 1406 600 cfm carb on my 350. Because of my HEI and air cleaner I have to use a 1 1/4" filter spacer. I am thinking of replacing it with a carb spacer, but I am wondering if that will give me more power. Have any of you used them before?
03-21-2010, 12:58 AM | #2 |
knuckle buster..
Re: do carb spacers really work?
just posted this link...click here
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) join the the smilies fight club |
03-21-2010, 01:25 AM | #3 |
Just Not Low Enough!
Good info 72swb, i always wondered about that.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
03-22-2010, 08:45 AM | #4 |
I have a similar set up on my 383, 1406 on top of a 2101 intake with HEI. I talked to Edelbrock for a bit and they seemed pretty confident that I would gain low end and maybe a bit of mid range torque. They were adamant that I use the 4 hole spacer as opposed to the open one. Maybe one of these days I'll buy one of those hybrid spacers, but I'll try this 4 hole for now. I just got the truck running a couple weeks ago, and haven't had the chance to really try it out though. It seems more "torquey" than before when I just had the 1/4" tall filter spacer.
03-22-2010, 09:13 AM | #5 |
DON'T TREAD ON ME
Spacers work but like the article says it depends on what you want from it, what kind you are using and what is the rest of your setup. I use a 1" open plain spacer on my engine. It makes a little more top end power at the expense of robbing some bottom end power. Since I have enough bottom end power to fry the tires whenever I want, it makes sense for me to move that power up in the RPM's where I can get some use from it. If you aren't making tire smoking torque already, then an open plane spacer is not for you.
That Super Sucker looks quite interesting. I might even try it some day and see what it does for Old Yeller.
Old Yeller |
