Old 03-21-2010, 07:29 PM   #1
fjthompsoniii
tach question
I'm told there is a link you can get to put in the wire from the coil to the tach to make our tachs work with hei, anyone know anything about this?
fjthompsoniii is offline   Reply With Quote
Old 03-21-2010, 07:35 PM   #2
67chevy2wd
67chevy2wd's Avatar
Re: tach question
I just ran the brown wire to the "tach" terminal on my HEI distributor. I am using a harness that I bought though so I am not sure if your wire color would be the same.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-21-2010, 07:45 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: tach question
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-21-2010, 08:05 PM   #4
Fitz
Re: tach question
try here or us this PN & order from summit or Jegs.
http://www.repairconnector.com/produ...Connector.html
Fitz is offline   Reply With Quote
Old 03-22-2010, 09:25 PM   #5
fjthompsoniii
Re: tach question
I think I need to clarify the tach is hooked up and works but it's inaccurate and wont go past about 3200 rpm I'm told that is because it's hooked to hei and there is some kind of resistor or something you can put in the wire to the coil that will make the tach happy with hei.
Old 03-22-2010, 09:41 PM   #6
67chevy2wd
67chevy2wd's Avatar
Re: tach question
There isn't a resistor in my harness? Can you find out if it is accurate up to 3200 rpm? Maybe it isn't calibrated right. Do you have a v6 or v8 engine?
'71 GMC 3/4 ton 4x4
Old 03-22-2010, 09:49 PM   #7
71swb4x4
71swb4x4's Avatar
Re: tach question
A stock tach will work just fine with standard HEI without any modifications.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-23-2010, 02:39 AM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: tach question
I know I ordered my tach harness from GMC Pauls and it is specific for a hei set up. So that may be what you need to do
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-23-2010, 03:37 AM   #9
Jeffs70
Jeffs70's Avatar
Re: tach question
if you have switched over to HEI you will also need to get rid of the ballast resistor due to you are not using points any more, a ballast resistor can cause all sorts of issues even with the Tach.
Jeffs70 is offline   Reply With Quote
Old 03-23-2010, 10:06 AM   #10
chipflyer
chipflyer's Avatar
Re: tach question
Mine is also a bit inaccurate, it actually reads higher than it should as RPM's increase. I have done a little research and have found that the HEI tach signal is a digital signal and the old tachometers are analog device's that expect to receive an analog signal. They just don't work very well together but can be improved if you add a tach filter. If you do a google search you will find many examples and I have added a link to an ebay item that may help in your situation. I have wanted to try one of those myself, just haven't gotten around to it.
Monte Carlo Tach filter
Here is a link to good info over on the vette forum Tach filter
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 03-23-2010, 07:25 PM   #11
fdbdw
fdbdw's Avatar
Re: tach question
double check the directions to see if there is a calibration that needs to be done, mine for example can be used on anything from a 2cyl to 12cyl, so when I hooked it up I had to go through the calibration proccess to get it acurate. List the brand and part # and I bet someone can help, good luck
fdbdw is offline   Reply With Quote
