03-21-2010, 08:30 PM | #1 |
Hello New to your Forum
Hello , Just joined your Forum and started a new Project. I just finished some horse trading and ended up with a 1964 GMC Big Window, ShortBox Fleet side and a Doner 1964 Chev 3/4 ton Long Box. The GMC has a 305 V6 4 sp. the Chevy has a 283 4 spd. The goal is to make a fun truck that can be a daily driver and not worry about the odd Scatch or stone chip. It will likely be a mix of the best parts of both Trucks. A 64 Chev ShortBox rolling Frame, Diff and Coil Suspension came with the deal aswell.
I will post pictures and progress later. looking forward to this project . |
03-21-2010, 08:46 PM | #2 |
Re: Hello New to your Forum
Congrats and welcome to the forum.
03-21-2010, 09:01 PM | #3 |
Check The Champ, Demonstrator
Pic's would be real nice. Gooday Eh! and welcome to the last site you'll ever have to go to.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-21-2010, 09:16 PM | #4 |
Member of the longbed union.
Welcome to the site. Post up some pics of those trucks when you get a chance.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
03-21-2010, 11:47 PM | #5 |
Senior Enthusiast
Welcome from Washington state. A lot of good ideas and support available here.
03-22-2010, 12:28 AM | #6 |
60-66 Nut
Welcome to the forum
03-22-2010, 06:13 PM | #7 |
283 Drama Queen
Welcome to the Loony Bin...... (Mac)
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
03-22-2010, 07:16 PM | #8 |
"Where were you in '62?"
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-22-2010, 07:34 PM | #9 |
BLAZER THIRTY!!
WELCOME FROM UTAH, (PS KEEP THE 3O5 V6 THESE ARE UNIQUE ENGINES AND WILL LAST FOREVER)
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
03-22-2010, 07:48 PM | #10 |
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
03-22-2010, 08:00 PM | #11 |
Yep,
Here is some info I found on the GM V6 that I thought was cool. GMC Truck produced a unique 60° V6 engine from 1960 through 1978. The engine was available in 305, 351, 401 and 478-cubic-inch (5.0, 5.8, 6.6, and 7.8 L) versions. In late production there was also a 432-cubic-inch (7.1 L) version with enlarged crankshaft journals. GMC also made a 637-cubic-inch (10.4 L) 60° V8 with twin balance shafts using the same general layout as the 305. Finally, there was a 702-cubic-inch (11.5 L) "Twin Six" V12, which was basically two 351s placed end-to-end with a common block and crank. A Diesel version was called the ToroFlow. The 305-cubic-inch (5.0 L) 305 had a 4.25 in (108 mm) bore and 3.58 in stroke (90.9 mm). The 305 V6 was the standard pickup truck engine for GMC from 1960 to 1966, and was one of the first V6 engines produced by an American company. The 351-cubic-inch (5.8 L) 351 had a 4.56 in (116 mm) bore and 3.58 in stroke (90.9 mm). It was basically an enlarged 305. In 1972, the 351 was replaced by a 379. The 305-cubic-inch (5.0 L) 305 had a 4.25 in (108 mm) bore and 3.58 in stroke (90.9 mm). The 305 V6 was the standard pickup truck engine for GMC from 1960 to 1966, and was one of the first V6 engines produced by an American company. The 351-cubic-inch (5.8 L) 351 had a 4.56 in (116 mm) bore and 3.58 in stroke (90.9 mm). It was basically an enlarged 305. In 1972, the 351 was replaced by a 379. The 379-cubic-inch (6.2 L) 379 had a 4.562 in (115.9 mm) bore and 3.86 in stroke (98 mm). The engine was further enlarged for the 401-cubic-inch (6.6 L) 401.It has a 4.87 in (124 mm) bore and 3.58 in stroke (90.9 mm). In late production there was also a 432-cubic-inch (7.1 L) version with enlarged crankshaft journals. The 477.7-cubic-inch (7,828 cc) 478 was one of the largest V6 engines ever built. Gross output was 235 hp (175 kW) at 3200 rpm and 440 ft.lbf (597 Nm) at 1400 rpm. Bore was 5.125 in (130.2 mm) and stroke was 3.86 in (98 mm). It was introduced in 1963 in the 6500 series trucks. It was superseded by the 1966 478M "Magnum" series, and production ended by 1974. Gross output was now 254 hp (189 kW) at 3700 rpm and 442 ft.lbf (599 Nm) at 1400 rpm. The 702-cubic-inch (11.5 L) V12 "Twin Six" was offered in United States GMC commercial trucks, and as a special order option in Canada. It was often mistaken as two V6 engines welded together but in fact was a single casting. It used four separate exhaust manifolds, two separate carburetors, two separate distributor caps driven off of a single distributor drive, and other parts from the 351. 56 major parts are interchangeable between the Twin-Six and the other GMC V-6 engines to provide greater parts availability and standardization. It produced 250 net SAE horsepower (190 kW). Torque was 585 lb·ft (793 N·m).
03-23-2010, 09:20 AM | #12 |
all the way from SE Texas. Put some pics up and keep us informed as you proceed.
" I never think of the future. It comes soon enough " - Albert Einstein |
