Old 03-21-2010, 10:30 PM   #1
AnlaufJohn
Wipers won't park.
Hello, and Happy Spring to all!
I am still having an issue with my wipers not parking when turning off the wipers. The patient is a 1966 C-10 LWB w/ 283-2bbl and 4spd.
I have the reproduction factory manuals and looking at Section 12, page 19, item E relates to the blades not returning to park when wipers turned off.
Yah!! I found the section. First thing to check is " Check wiper ground strap connection to car body."
The books don't show what this ground strap connection looks like, or where it is located.
OK, is this the not-connected ground strap connection? See attached photo
AnlaufJohn
Soggy & sunny Springfield, Oregon
AnlaufJohn is offline   Reply With Quote
Old 03-21-2010, 11:41 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Wipers won't park.
The same problem developed in the original wiper motor that came with my 1960. I consulted the factory service manual which indicated:
2. Wiper blades fail to park
This condition is caused by parking switch contacts (fig. 147) being dirty or broken. To inspect and/or clean contacts, disassemble gear box.
Since this was my daily driver and I couldn't be without a wiper motor, I started looking on eBay and eventually found a factory rebuilt unit relatively cheap and replaced the original, which cured the problem.
In case it truly is just a grounding problem I'd just hook up a length of wire to any bare metal portion of the wiper motor you can reach, and connect it to a known good ground (even to the negative post of the battery if necessary) even if it's only temporary. That should clarify if a good ground will resolve the problem or not.
Old 03-25-2010, 06:17 AM   #3
AnlaufJohn
Well, that little tab in the picture does need to be grounded.
Tonight, it started to rain again, and I put a short jumper wire to it and grounded the other end.
Yippee!!!!! The wipers park themselves, now.
What an easy and amazing fix. So thank you, markeb01, for that suggestion.
It is still raining and I won't have to worry about timing the switch anymore.
AnlaufJohn
Old 03-25-2010, 07:07 AM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
The ground strap was a thin flat(.375-.5") piece of brass??
going from main body of motor to firewall (because it's mounts are rubber insulated)
Haven't seen one with a plug-in connection like that though
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 03-25-2010, 11:20 AM   #5
AnlaufJohn
Well, 63sbssbbw, the picture shows the brass tab like you mentioned.
There is no provision for it to plug into anything. It probably should have been placed under that lower mounting bolt. Someone else worked on the wipers before I bought it, so it's their mistake, and my joyful surprise!!!
I will remove the bolt and thread it through the hole of the brass tab and see if that allows the wipers to park. If so, then it's a done deal.
AnlaufJohn
One happy dude in Springfield, Oregon
Old 03-26-2010, 07:09 AM   #6
63sbssbbw
UCA63
63sbssbbw's Avatar
As Markeb01 has mentioned it's definitely a ground issue
I had disassembly pics of this strap(3\8' x 2 1\2"),but lost them to a comp crash
Also you'll find that bolt(with the funky nut on the other end) are a major PITA.
You could find a connecter that fits that tab(or solder it) and run it to known good groundThanks
T
member#7816
'61 GMC in progress
