Hey Watch this...
![]() Join Date: Sep 2007
Which Transmission?
Hey guys. I'm back in 'project mode' with the '64 and I'm really yearning to get rid of the granny 4speed in the truck. Can y'all point me in the direction of what transmission would work in place of it? What I want is a 4speed manual, that will work easiest with the sbc (currently a 283 but I'm looking at a 327).
Thanks!!
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
Senior Enthusiast
Re: Which Transmission?
If you're still running the original bellhousing trans mounts, the easiest thing would be to pull the transmission and slap in a Richmond Super T10 or a Muncie passenger car 4 speed. Depending on what driveshaft arrangement you have you may need to lengthen the shaft and maybe change the yoke. Some use a slip joint and some use a bolt on arrangement.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Depending on your HP plans for the engine you might be able to get away with a Saginaw 4 speed. They can be had for less $$ than a Super T10 or any of the Muncie's. But then the Saginaw won't hold up to much HP and abuse.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-22-2010 at 12:46 AM. |
Hey Watch this...
Great information guys, thanks. I'm planning to keep the hp at about 300 max, probably actually less. Nothing crazy.
fan of "Butters" Stotch
I'll be running a 4 speed Saginaw, but only because I got a smokin deal on it; I'll have to be a little easy on it.
Muncies and T10s are better, but expect to pay the big $$ A Muncie in good shape will go for at least $700-$800
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() Last edited by tapeworm; 03-24-2010 at 05:06 AM. |
Hey Watch this...
Yeah I'd take almost anything that bolted up right now actually. For some reason I loath the granny first, and then the super wide spacing of the three usable. I almost entertained the idea of an automatic, but then the booze wore off.
Airport Bum
There is no way I'd go to the trouble of fitting a transmission without an overdrive.
Not in this day and age.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
#8 | |
I feel kind of the same way, but there are no real easy or affordable options The Chevy T-5s are pretty weak and not worth the trouble (imo anyways, but I'm sure there are fans out there) There is a 886? 4sp O/D tranny out there, but I think they are pretty hard to find The Tremec TKO500 and 600 trannys are great, but very expensive and are pretty big
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
Airport Bum
I have seen Saginaw 4's with a 3sp OD added.
But a Saginaw is just as weak as a T5. I just want to go to the Hunnert Car Pileup without floating a loan. ![]()
#10 | |
![]() Last edited by halfcockedcustoms; 03-24-2010 at 11:32 AM. |
i agree....T5. Best bang for the buck especially with 300 HP
there is acouple of other options. aint never seen one but aa makkes an od unit that fits between the clutch housing & trans. bout 3" wide or so. then in the 80s ford made an od trans that was like the gm saginaw that was behind the diesels, but it was based on the old toploader. there were others that were aluminum but i wouldnt use them. the toploader was a good one, i ran one in my 72 nova for a long time & it worked great. used a b&m scatershield that had the chevy / ford pattern on it. ford put them in trucks behind small blocks with a 3.00 gear & the engines just bogged. they liked a 3.55 or 3.73 lots better. worked for me!
andy Last edited by andyh1956; 03-25-2010 at 12:27 AM. Reason: mispelled word |
#13 |
Good point
Not sure if you'd have to shorten the driveshaft and such with the T-5 I can say that I would def pic a T-5 before I'd pay some of the $$ people want for their Saginaws
