03-22-2010, 11:15 AM | #1 |
seat platform removal?
I'm helping work on a '50 panel truck and it has the original seats up front.
We managed to remove the drivers seat, but it looks as though the platform that the seats are attached to is removable (at least, the drivers front corner comes up a few inches) but we cannot find any way to "unlatch" it. Is it in fact removable? And if so, how? Any help is appreciated! Scott
1970 C10 Fleetside longbed 350/TH350 Last edited by shrike; 03-23-2010 at 02:37 AM. Reason: pic added |
03-23-2010, 10:20 PM | #2 |
Re: seat platform removal?
I am not sure about that since I am working on a reg cab truck and the seat was removed before I got to it. I don't know if this helps or not but the floor mount is spot welded to the floor. I did cut that out. The way I did that is to plasma out the majority of the frame and then drilled out the spot welds. It looks like in your pictures that the top portion is removal and the floor mount is like the truck that I am working on. Hopefully someone else has removed that top piece.
Bernie |
03-23-2010, 11:32 PM | #3 |
Is the 1954-earlier assembly manual still printed...?
03-24-2010, 05:08 PM | #4 | |
1970 C10 Fleetside longbed 350/TH350 |
03-24-2010, 10:03 PM | #5 |
Junior Member
Take it off, take it all off!
I have the 'dipped' floor out of my burb, you want me to splice & dice and show you a cross-section?
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck |
03-24-2010, 10:23 PM | #6 |
That would be awesome, trying to get an answer before the weekend (when we go back at it!)
03-25-2010, 03:55 PM | #7 |
Yes, a guy can find it on Ebay pretty easily. I've got one and it actually is more 54 than pre but it helps lot when you get into the "how did they do that" questions.
Most guys take the seat riser out in a manner similar to what pgf545 said he did his. I've take them out of pickups by using a torch to cut the main part of the riser out and an air chisel or hammer and chisel to get the rest out as I didn't have a spot weld cutter when I did them. 't |
03-25-2010, 09:51 PM | #8 |
Sorry, I am not being very clear I didn't realize that so many people removed the entire riser!
For now, we just wanted to know if the top part of the riser (the part the seats are actually bolted to) is removable. It looks like it is just a cover, and it is loose in one area: Is this something Chevy meant to be opened? And if so, is there a trick to it? It doesn't look like it's welded (although I could very well have missed it)
03-26-2010, 05:52 AM | #9 |
AD Addict
Or go here: http://chevy.oldcarmanualproject.com...uck/index.html
I think you need the assembly manual, though. Mine is here but I'm running to work. I can look later. Last edited by Dan Bowles; 03-26-2010 at 05:55 AM. |
