? How to Lower 1980 C10 1/2T
what's the most economical kit or kits to lower my 80 chevy big10.
want to drop front as much without altering ride and parts also rear ??? who is the lowering king out there ? |
Fabricate till you "puke"
2" is about max you want to go on a front spring, If you need more I would go with a spring/spindle combo. At the rear, you can do a 4" drop with a shackle & front spring hanger, or a 6" drop with a flip kit & a C notch. good luck.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Calibration Engineer
first u gotta decide on what drop you want, then choose from western chassis, djm, or belltech.. also gotta decide if you just want maximum drop, ride quality, or cheap as possible..
