Old 03-22-2010, 01:16 PM   #1
DaPrato300
1962 Fleetside needing bags
I have a 62 Fleetside I want to bag. Will the newer A-arms (73-87) bolt on to remove the torsion bars and then just build a plate off the frame or will it require replaceing the front suspension first and build off a 73-87 front suspension? This is a daily driver truck so I aint looking for it to lay frame or a show quality job. I am looking for functionality.
DaPrato300 is offline   Reply With Quote
Old 03-22-2010, 01:28 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: 1962 Fleetside needing bags
You can remove your torsions and plate the lower a-arm. Use a plate above the bags as well and you're done. .....except with the switches, compressors, wiring, tank, etc.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
