Anyone know a low buck way to drop a straight axle front end?
Hi guys. I have a 1953 1/2 ton that I building with a very small budget. Anyone have any ideas or experience on lowering the front end on one of these. The previous owner started a frame off and the frame is in nice condition so I hate to clip it.
Re: Anyone know a low buck way to drop a straight axle front end?
De-arch the springs or make a bracket to put the axle on top of the spring. That is lo-buck.
Spending some money will get you a dropped axle or 3" lowering springs. |
www.droppedaxle.com Cool guy. Affordable drop axles and he gives money for cores. He deals on ebay and has a great rating.
I have one on my truck.
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! Last edited by bensimmons_05; 03-22-2010 at 04:29 PM. |
I put the wrong link to begin with.. I changed it.
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
AD Addict
That's Sid. He's the best around. Scrounge up some cores and you may be able to get it cheaper than you think. I've got 3 so far. Someday I'll send him one and then go pick it up with all the cores!
Thanks guys. This really helps. My 53 just seems so high. Maybe thats normal but I bet the running boards are 12 inches off of the ground. Maybe its me being a newbie to original ride height.
getting rid of the stock wheels and tires would help too.
On HAMB there are a couple of threads about his axles, I think one even shows the process. A search over there for chevy truck dropped axle might find it..
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
IF you are really tight on money you can flip your front axle.
http://www.jalopyjournal.com/forum/s...d.php?t=245130 WAY more trouble than a drop axle but almost free if you have the tools to do it. |
AD Addict
Only 12" to running board height? Wow, your's is already lowered. Mine's at 13"!!! You don't need ramps to change the oil but you need a step to get into the truck. Welcome to stock height.
Thanks 'til you're better paid
There is some good info on both of those links! Thanks.
-Luke 1950 Chevy AD 3100 pickup 2000 GMC Sierra 1970 Jeepster Commando |
Thanks for confirming that 12-13 inch height is normal. I just guessed at 12 inches for mine. I bet your right at 13 inches. I was thinking that it might be a 3/4 ton or a 4x4 when I first bought it. It was my first experience with a stock frame.
#13 |
I agree there is lots of good info on those links. Thanks for the help all.
#14 |
i did it for free.... remove 3 leafs and manufacture a bump stop. use 14" rims and low profile tires... you will be dragging!! (over speed bumps). it aint safe but it's low!!
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#15 | |
![]() I think it had 205-70 14's on the front in this photo. I have run 195/14 and like the look better with them. 14x7 Enkie 32 wheels on front and 15x8.5 on the rear with 255-60/15 tires. |
