bed tie downs, hooks...whatever
since there are none in any of the parts books, what are you guys using for hooks or loops or whatever in the bed?
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: bed tie downs, hooks...whatever
yeah, there is. Called a "cargo tie down" -GM accessory booklet 1972
![]() Hope this helps. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by 71blksuper4x4; 03-22-2010 at 09:26 PM. |
Between Trucks...
I am going to go with these in the bed: http://www.summitracing.com/parts/CHT-J-704/
I think Harbor Freight sells something similar. I have some chrome tie downs on the bedrails I got from LMC.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 03-22-2010 at 09:26 PM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Before I got a drop-in bedliner, I had eye-bolts (5/16", iirc) in place of the front corner bed bolts. Maybe not elegant, but worked well.
SWB 4x4 Collector
Any 73-up bedliner should fit. Also, I think I recall people saying mid to late 90's Dodge bedliners will work. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
20' Daredevil (Ret)
I got an All Star universal.... supposed to be same manufacturer as Duraliner, just their cheaper line. It turned out to be a very good fit, the wheelwell shape was even the same. And you're right, it was quite a few years ago.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 03-23-2010 at 12:51 AM. |
Big Red - Now its a SWB!
Here is what I plan on putting in my truck soon http://shop.easternmarine.com/index....categoryID=291, I had them in a ranger that I used to have and they work great. They are the same as what all the truckers have in the freight trailers. There are tons of different accesories that hook to them. I've found them at tractor supply, I sure that they aren't to hard to find.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
I bought the tie downs that slip down into the stake pockets. I bought 2 types. The first where the cheaper one that used a butterfly anchor, an eye-bolt, a plate, and a rubber pad. They worked, but looked cheap. The second and better looking ones, had a stud, a screw plate, a rubber block, and a threaded loop. I never like the look though, the loop sticking up out of the bed, but I needed something.
So, one day I got an idea. Dangerous, no? ![]()
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Redefining LowBudget
I'd like a pic of the Eraser??
my thought is to go see the race car guy have him put 2 90* bends in a piece of 1 3/4" roll cage pipe...so that the ends are even with the front and rear stake pockets..( this maybe hard to explain but you see them on newer trucks) then cut 3 plates that cover the stake pockets drill a hole in the center and weld a nut on the back side so that a bolt can be tightened from the bottom of the stake pocket (the bolts will be about 6" long) place the plates on the bed set pipe on the plates ( your going to need to have 1 short piece cut with the diameter of the pipe for the center pocket) and tack them...take the bolts out and finsh weld the platesont he pipe and paint it ( I'm going to paint it to match my steel rallies) but hen again I was just loking for a pic to post and found these in 96" that may work well for our trucks and I wouldn't have to build it..and there pretty cheap since th materials to but it is $$3.50 a foot with the bends http://www.truckchamp.com/products/T...ml/refer=true#
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
![]() Join Date: Sep 2000
Eraser that does sound like a good idea. Pic's would be most helpful.
69 stepside, 1/2ton, 4X4, 350/350/205 |
OK. Here they are. I did not have enough light inside of the stake pocket for pictures. The middle pocket used the screw plate that I mentioned. The front and rear pockets used the butterfly anchor doohickeys. I may change out the rear cast loop for the steel eye bolt due to strength. you may notice that the plates overhang the pocket a bit. I intended to cut the plates flush, but never got a round tuit. For better or worse, it works.
Middle [IMG] Rear [IMG] Front [IMG] As I remember, there was no hole in the rear pocket, just an indention. I drilled the indent. Still, who would know except us?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 Last edited by ERASER5; 03-23-2010 at 04:04 PM. |
#13 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Here is what I did when I built the "Garden Truck". I found these tie downs at Home Depot. They are chrome plated cast metal of some sort. They were like 11.95 per pair and it took 4 pairs to do the job. I just used threaded rod to bolt them together. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#14 |
Never Ending Projects
That's a clean setup Wes!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#15 |
I seam to have seen that somewhere else.
#16 | |
#17 |
454 MAKES IT ROAR
I like the pop-ups...there are a few different types out there.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#18 |
I was thinking of using a 2" u bolt with a spring on the bottom of each side and a 2X2 1/8 in steel plate with 2 lock nuts.... that way when your not using it, the springs will hold tension on it so it wont be rattling when you drive. Just pull it up when you need to use it. Sort of like what some Goose Neck hitchs have for the safty chains.
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster Last edited by Strut; 03-23-2010 at 09:11 PM. |
#19 |
Grandpa in the rustmobile...
how much would a spray in liner cost for a lwb fleetside?
Also, whats the best way to prep for it? wire wheel, nothing? sandblast?...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
