Old 03-23-2010, 11:00 AM   #1
NicoSlam
need advice on 20" tires
I purchased a set of boss 315 20" (8.5") with 305/50/20 tires. I tried to fit on my truck but the tire was obviously too big for the front. The rear fit with 1.25" spacers but I need help on selecting the front tires. What is the narrowest tire I can put on an 8.5" rim? I see many threads where 255/40/20seem to be common but can I go narrower. Once I select the width I can play with the aspect ratio to match the rear. I have a 1969 with a 4/6 drop. Pics of trucks with 20"s on 1967-70 with a 4/6 drop would be great.
NicoSlam is offline   Reply With Quote
Old 03-25-2010, 03:08 PM   #2
NicoSlam
Re: need advice on 20" tires
Anyone???
Old 03-25-2010, 03:19 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I saw this thread yesterday, but forgot to respond.
IMO... the best tire size to run (on an 8.5" rim) will be a 255/40 up front and a 295/40 in the rear. For an 8" rim I would change it to a 245/40. On this type of decision... I prefer to not have a lot of space between the wheel/tire setup and the fender (I like it to not look 'spacey')
Do you know the BS on the 20's?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-25-2010, 03:34 PM   #4
NicoSlam
Spacing looks to be 5.5". I tried them on on they fit great even the centercap. Unfortunately, I couldn't get out of the driveway without the tire rubbing on one of the innerfender bolts. The rim looked to have good position but the 305/50/20 seemed too wde.
Old 03-25-2010, 10:18 PM   #5
hemihead
hemihead's Avatar
Thats a huge tire for the front, I went with a 255 45 on a 8.5 inch rim and a 295 40 rear on a 10" wide.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 03-26-2010, 01:42 AM   #6
cstm68
cstm68's Avatar
im running a 275-45-20 4-6 drop before i went to bags and never had a problem
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 03-26-2010, 01:18 PM   #7
epashhans
epashhans's Avatar
Hey Nicoslam, here is a post with some pictures of the rims/tires I have. They are boss's as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=370922
And here is another thread with the same photos but a little bit of a write up on what I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=389784
Hope some of that helps! I know some people think the tires look to big, but I don't like the look or ride of rubber bands.
When you get something figured out, make sure to post some pics!
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 03-26-2010, 01:26 PM   #8
NicoSlam
Thanks for all the advice. I'm going to get new tires for my tundra so I'll use the old ones as a start point. they are 275/50/20. I'll get picks up this weekend. I'm also doing the saginaw to A833 swap also. Will be an interesting weekend.
Old 03-26-2010, 01:39 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nico... can you explain the A833 swap? Sorry... haven't seen that one before.
-Nate
Old 03-26-2010, 02:04 PM   #10
epashhans
epashhans's Avatar
You got a 440 in that thing? That WOULD be quite different...mopar driveline in a chevy. I'm liking that! I should put the 454 out of my truck in my charger and the 440 out of the charger in my 67...kidding!
Old 03-26-2010, 02:09 PM   #11
NicoSlam
The A833 or MY6 is a 4speed floor shift tranny with 4th gear being overdrive (.67) that came out on the early 80's chevy 1500. It's the same length as a saginaw so theres no need to modify driveshaft. At 70mph, you can cruise at 2100rpm. Has similar gears as a 700R4
Old 03-26-2010, 02:24 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the explanation!
Keep us posted on the install...
-Nate
Old 03-26-2010, 02:27 PM   #13
NicoSlam
Not the best pic but this is what it looks like: The trans originally was created by mopar but seems chevy borrowed the design in the 80's
Old 03-26-2010, 03:03 PM   #14
grancuda
grancuda's Avatar
I have been looking for one of those 4 speed OD manuals for a while
grancuda is offline   Reply With Quote
Old 03-26-2010, 03:18 PM   #15
NicoSlam
Grancuda, you and me both. I must of hit all the Junk yards in San Antonio. did find several mopar versions but no MY6. I ended up finding one through another forum. I bought it and literally the next day, I found another so I bought it too. Anyway, I have an extra one. Nogalitos gear has a rebuilt one on the shelf but they want $750. It was a little high for me. Passion performance can rebuild for about $500 if needed. I've ordered all my seals and gaskets from them.
Old 03-26-2010, 05:03 PM   #16
grancuda
grancuda's Avatar
you looking to sell you extra one?
Old 03-26-2010, 05:09 PM   #17
NicoSlam
Grancuda. look at your PM. We cant discuss on thread
Old 03-29-2010, 09:53 AM   #18
NicoSlam
I had issues with the tranny hitting the cab floor so I didn't have a chance to install the wheels. Here is a better pic of the wheel I took this weekend.
Old 03-29-2010, 02:14 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice looking wheel Nicoslam!
-Nate
Old 03-31-2010, 04:19 PM   #20
NicoSlam
Any tire size suggestions and pics with a 4/6 drop?
Old 03-31-2010, 04:57 PM   #21
epashhans
epashhans's Avatar
I thought you were going with the tires off the tundra?
Did you look at this thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=361157
There are lots of pics and tire sizes in there...mostly on 3/5 or lower drops.
71bb_lwb is running close to what you would be with a 4/6...275/45/20
Old 03-31-2010, 08:11 PM   #22
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
275/45/20 x4
5/7 drop very close to 4/6 and no rubbing with my drop which is an inch lower all 4 corners.
Wheels are 20x8.5 all 4 corners.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 04-01-2010, 02:20 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Still sticking with my suggestion of 245/40 or 255/40 for the front and 295/40 for the rear.
-Nate
Old 04-03-2010, 10:20 PM   #24
NicoSlam
Finally got the tires installed today. I decided on the 275/45/20 Falkens. The front is perfect but the back needs o be spaced out about 1.5". The rims are Boss 315 8.5" with 5.5" back space. I have the 4/6 ECE drop and am thinking of going down another 1/2" using 2" frt spring and 1/2" spacer for the rear. Anyway, thanks for everyones support and suggestions.
Old 04-03-2010, 10:43 PM   #25
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks good Nico... I've got an update as well...
Wheel/tire specs over on my build thread.
255/40-20 and 295/40-20
-Nate
