Old 03-23-2010, 11:16 AM   #1
tanner
removing steering column
how do you remove the steering column on a 71k5 blazer
tanner is offline   Reply With Quote
Old 03-23-2010, 11:25 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: removing steering column
It should come out like mine did in my '69 2wd.
Disconnect it at the rag joint on the steering sector. There's a clamp on the firewall (engine side) of the column. There's 4 bolts, if I remember, holding the column to the bottom side of the dash. Oh, there's an electrical connector between the backside of the dash and the inside of the firewall. I'd do that item, first....so I didn't forget. If you have a column shifter, you'll have to disconnect it, too. If it is an automatic, there will be a "tab" that holds the linkage to the transmission. If it is a manual (3 on the tree), there should be 2 linkages to disconnect.
If anyone sees that I muffed this advice, please chime in and help a bud.
Member Nr. 2770
Old 03-23-2010, 11:51 AM   #3
Schwinn68
Schwinn68's Avatar
I'm subscribing as I'm going to have to do this very soon too.
Ben
_____________________________________
1971 Chevy shortbed 350/4-speed sold
2005 Chevy Duramax EC/4x4
Local 597 Pipefitters
certified TIG MIG and stick welder
Schwinn68 is offline   Reply With Quote
