Old 03-23-2010, 02:34 PM   #1
drewdude92
72 chevys 4 life
drewdude92's Avatar
miss at slow acceleration and cruise
My truck has a little miss when accelerating normal and at cruise going thirty forty fifty and seventy just whatever. It runs perfect idling and laying it to the floor. Ive looked at my plug wires when it is dark outside and can see a tiny glow coming from plug wires 2, 3, 4, and 7. I replaced the plug wires with others just to see and its still i small glow. I dont know whats going on for sure. Also if your getting up to speeds very slowly sometimes it will backfire. it sounds like its coming through the carb.
any help would be awesome. thank you
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 03-23-2010, 02:39 PM   #2
Security guy
Security guy's Avatar
Re: miss at slow acceleration and cruise
Just get a toyota gas pedal installed and that will fix it all. Just kidding, not for sure but it could be timing is off a little or carb may need some adjusting. Is all your vacuum lines hooked up corectly or open ports blocked off some how? You shouldn't be getting any glow from wires. Did you replace them with new wires or some used ones? Try siwcthing wires around if you have used ones to see if the glow changes as well. ??
Security guy is offline   Reply With Quote
Old 03-23-2010, 02:42 PM   #3
drewdude92
72 chevys 4 life
drewdude92's Avatar
yeah my plan for today is spray carb cleaner over intake to check for vacuum leaks... i didnt switch a plug wire that i knew wasnt glowing with one that is glowing. ill try that. so im still stuck with timing, vacuum leak, or wires. thats prob all ill get with out someone actually looking at it.
Old 03-24-2010, 12:19 AM   #4
BLK96
I had an issue with a miss only during light accel or cruise, turned out to be a bad reman distributor. Would only occur during vacuum advance operation, didn't happen with idle or heavy throttle where there was no vac advance. Doesn't explain your wires. Good luck.
BLK96 is offline   Reply With Quote
Old 03-24-2010, 12:53 AM   #5
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Its hard to tell by your avatar, but do you have headers? If you do, make sure the wires are not touching them. I had a similar problem, turned out to be burnt wires ( they did not glow), also the plugs for # 5 & 7 cylinders where backing out. Check all your plugs and make sure they are tight.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 03-24-2010, 06:00 AM   #6
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Quick question How does Carb cleaner work for checking vacuum leaks isn't it flammable?
A miss at slow acceleration,timing would be my guess, I was driving around like that for a while found out my distributor tie down bolt was loose so timming was off fixed it now no back fire..
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 03-24-2010, 08:20 AM   #7
cdowns
cdowns's Avatar
sounds like a vaccume leak/ timing /or running very lean
carb cleaner will cause motor to speed up if it's sucked in thru a vaccume leak// check condition of sparkplugs theres charts in service manuals that will help you "read" the spark plugs
Old 03-24-2010, 01:37 PM   #8
drewdude92
72 chevys 4 life
drewdude92's Avatar
alrighty ill try to advance my timing just a tad more. I advanced it a little yesterday and it made the problem a little better. But if i did it anymore it would diesel on when i kill it. so idk whats going on for sure. Im gonna buy new taylors then mess with the timing a little more
Old 03-24-2010, 03:43 PM   #9
petey-pablo
"THE GREEN GOBLIN"
Cool I did not know that, it's nice to learn something new Thanks....
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 03-24-2010, 07:30 PM   #10
D-Rat
D-Rat's Avatar
Please post up what you find out. I've been chasing this for a while now. Feels almost like someone is lightly tapping the brakes when I'm at a steady speed and I'm getting the backfire occasionally too.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 03-24-2010, 10:09 PM   #11
Security guy
D-Rat, how old is your motor? I haven't had this happen before, but is your timing chain old enough to strech causing the timing to jump around? Just thought I would throw this out there.
Old 03-24-2010, 11:42 PM   #12
drewdude92
72 chevys 4 life
drewdude92's Avatar
yeah thats kinda what mine is like also. i advanced it a tiny bit more and got it running better still. gonna advance a tiny more tomorrow then tighten my distributor clamp down for good!
Old 03-24-2010, 11:59 PM   #13
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
What carb are you running? I have a holley 670 street avenger that was still at stock jetting, and it did the same think + some bucking with light acceleration. I did some research and found that they are jetted really lean from the factory, so I upped the jets some today (found some good starting recommendations online) and that made a huge difference. I just got back from some test cruising and I had a smile plastered on my face! Not only did it fix the bucking and missing, but it made the top end pull alot harder (4000+ rpm). Good luck tuning yours.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-25-2010, 10:27 AM   #14
D-Rat
D-Rat's Avatar
It was a complete rebuild only 12k miles ago.
Old 03-26-2010, 12:31 AM   #15
50mercfan
50mercfan's Avatar
Are you running an HEI distributor? If so make sure your plug gap is correct. I set mine at .045. Also, make sure your plug wires are crossed and not running parallel to each other. I the wires are running side by side they can jump spark to each other.
50mercfan is offline   Reply With Quote
Old 03-29-2010, 01:45 PM   #16
drewdude92
72 chevys 4 life
drewdude92's Avatar
I got my timing set about right now. Still got bout three plug wires glowing right at the spark plug. Im ordering some new taylors here soon.
Old 03-29-2010, 10:00 PM   #17
gonzo6869
gonzo6869's Avatar
Have you checked to see if the wires that are glowing are burnt. If you have headers that is a common problem. When you get your new wires, make sure they kept as far away from your headers, if you have headers that is.
Hope the new wires will fix your problem.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 03-30-2010, 03:26 AM   #18
Jacfourteen
They also have header spark plugs that are a little shorter to help out with header clearance too. I think they are made by accel.
Old 03-30-2010, 11:35 AM   #19
1969K10
1969K10's Avatar
have you checked your timing chain for stretch? put a light on it, and see if it's steady, or bounces around a little.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 03-30-2010, 01:25 PM   #20
drewdude92
72 chevys 4 life
drewdude92's Avatar
yeah me too im gonna get the taylors that say are made for headers. and it couldnt be my timing chain since it has a gear drive haha
Old 03-30-2010, 01:46 PM   #21
Sinister
Between Trucks...
Sinister's Avatar
I think you need to tune your carb.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-05-2010, 01:39 PM   #22
drewdude92
72 chevys 4 life
drewdude92's Avatar
I put new plug wires on and still getting a little glow from cylinders numbers 2,3,4,and 7
Im gonna replace the plugs now. They were brand new when i started having this problem. Is there a chance that someone could have dropped the spark plugs and messed up the porcelein or something?
Old 04-05-2010, 02:52 PM   #23
longhorn396
S.D.M.F.
longhorn396's Avatar
i am having the same problem
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 04-05-2010, 02:53 PM   #24
drewdude92
72 chevys 4 life
drewdude92's Avatar
well ill let you know if i figure it out and you let me know im doing the plugs either today or tomorrow
Old 04-06-2010, 01:35 PM   #25
drewdude92
72 chevys 4 life
drewdude92's Avatar
changed the plugs and still the same problem. is there any way it could be the carburetor? When adjusting the two screws on the front of an edelbrock the motor should want to die when screwed all the way in right?
