Junior Member
will 33's fit a 3/4 2wd
Pics if you have them.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: will 33's fit a 3/4 2wd
I think it would be a bit close if they do.
1969 ![]() |
HickTown
i am pretty sure i have 32's on my 68 c20 and they fit alright
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
Rottenwood Garage Member
Im fairly sure they will rub in tight turns!! Depending on the width of the rims and how worn out your springs are will also play a role in the equasion........
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Junior Member
Any one running 32's then? I know 31's are no prob cause I run them on the 1/2 ton. Any one know of a 2wd lift kit? I have searched and found nothing.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 03-23-2010 at 09:26 PM. Reason: add info |
#6 | |
Aim is not recomended but they will have what you need
HickTown
lmc sells a 3 inch body lift. and as above i am pretty sure i run 32's, and they work fine on my 68 c20
Junior Member
Thanks 72Freak but I will pass on AIM.
Location: Help! I'm in an office park with its own network of freeways!
I'm running LT235/85R-16s (31.75" on paper, 32.5" measured) on mine without any rubbing. Even with the old, tired springs up front I had no rubbing.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
I've got 33's on a 4 inch lift... and rubbing in a tight turn. I'd have to measure the tire width...cannot recall of hand. I can also take a pic if you want. I actually need to figure out what's going on...it's driving me crazy. I want to make sure I can run a 33 with steelies... as that is the path I'm taking.
Doug '72 GMC K2500 Suburban 4x4 |
You can run 33 on a stock C10. A C20 will do fine. I looked for an old thread about 2WD lifts and the lack of them. I could not find it. One of our members runs a C10 on 33s without any lift. C20s have more clearance.
Rim offset is often the problem
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 Last edited by ERASER5; 03-23-2010 at 10:57 PM. |
I'm going this route and worried about the same thing. Look for posts by stllookn, he has 33s on a C20. I've test fitted the 33s on mine but for various reasons wasn't able to check if they rub in tight turns.
I'm hoping to get things sorted out and do a proper test this weekend. You can see there is a lot of clearance, but turning will be tight. ![]()
Curry in a Hurry: SB rebuild for my 71 C20 |
#13 |
A neighbor had a 70 3/4 ton 396 with factory "wide" rims all the way around. The stock tire size was 33 x 12.50 x 16.5 with no rubbing... I'm not sure what the spacing on the rims is to allow for this, but it didn't stick out and looked fine. I ran 275/85/16's on my 1 ton. On the right side, I had to trim about a 1/2" off of... something, don't remember what, but I think that is because my rim spacing was for narrower tires.
#14 |
Moderator
![]() Join Date: May 2007
Here is my 72 C/20 2WD with 33 x 12.50 x 16.5 tires. It rubbed slightly when I made a right turn, but I attribute that to 40yr old ball joints, springs, etc. It had no rubbing when turning to the left.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#15 |
Junior Member
Thanks guy and thanks for the pic leddzepp. I think 32/10.5 is about max for me.
#16 |
265 75 16 is pretty much a 32 11.5 16. I ran those on my 70 C2500 Sierra Grande and they were fine. No rubbing and a good size IMO. I ran mine on 16x7 Alcoas.
