Old 03-23-2010, 08:32 PM   #1
68chevyfuelie
68chevyfuelie's Avatar
12 bolt truck gears
So, I'm kind of an idiot...I had a set of 2.73 and a set of 2.76 gears kicking around, in the process of rearranging the garage they got mixed up. I'm assuming I can just count the teeth on the gears, and figure out which pinion goes with which ring gear. I was just curious if there was a website or a link to a thread where carrier and ring and pinion numbers are. I have one for Dana stuff, but nothing for GM Corporate stuff.
As a side note, I believe the 3 series carrier was for 2.76 to 3.73, and the 2 series carrier was for 2.56 and 2.73 only, correct?
Is this stuff even worth hanging onto, or should I chuck it next time I take scrap in?
Thanks everyone.
68chevyfuelie is offline   Reply With Quote
Old 03-23-2010, 08:45 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 12 bolt truck gears
you can chuck it in a box and send it to me!!! I need alot more gear in my truck for the caddy engine to beat!!!
I would count them up and try to roll one around the other to confirm!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-23-2010, 09:05 PM   #3
1971gmcshortbed
1971gmcshortbed's Avatar
Divide the ring gear teeth by the pinion gear to be sure,
1971gmcshortbed is offline   Reply With Quote
Old 03-23-2010, 09:31 PM   #4
americanmusc1e
americanmusc1e's Avatar
the ring gears should have the number of pinion teeth and the number of ring teeth stamped on it seperated by a colon. for example......... XX:XX on a 3.07 rear end it would be 14:43 or 43:14 I can't remember which is first
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-25-2010, 10:19 AM   #5
grayw0lf
It's also likely stamped on the side of the ring gear. It'll say 43:14, or whatever.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 03-25-2010, 04:51 PM   #6
Hottrucks
Hottrucks's Avatar
heres a pic of a ring gear#
