Old 03-23-2010, 10:37 PM   #1
lowchevytrucks8503
14 bolt rear end
i was curious if any of you guys have put a 88-98 rear end in a 73-87 c10. or even used a 454ss 14bolt. I was wondering what the width differences were. thanks
lowchevytrucks8503 is offline   Reply With Quote
Old 03-23-2010, 11:30 PM   #2
USSkoval
Re: 14 bolt rear end
I will be putting a 6 lug 4x4 version in my '77 Blazer 4x4, IIRC it's 1.5 inches wider per side. I think the 2wd version is about the same width the stock 1/2 ton rear. The bump stop plates and spring perches get cut off, then new spring perches welded on. I am leaving the shock mounts in place because I think they are in the correct location to be used as offset mounts.
USSkoval is offline   Reply With Quote
