'65 leaning a bit
![]() Readjusted the right rear spring today thinking it was out of place. No solution there. When I go around a corner though I get that grabbing feeling from the rear. I mentioned this in a post a few weeks ago, but now wondering if the panhard bar is to blame for drag and the leaning? Curious as to what you all think. '70GMCStep '65 Chevy C-10 ![]() '70 GMC Stepside ![]() Last edited by '70GMCStep; 03-23-2010 at 10:52 PM. |
![]() Join Date: Nov 2008
Re: '65 leaning a bit
I would start out by going to all 4 corners and measure the ride height ... If the L/f looks like the problem , have someone or use a jack to see if lifted at L/F if the problem remedys its self ... If it does I would maybe look at new front springs and posssible ft. shocks ..
![]() Last edited by 62 Longbed; 03-24-2010 at 12:09 AM. |
my sons 64 did this after he put some blocks on top the rear springs to pick the fenders up off the tires. i noticed it sitting funny & when he drove it into the shop i saw the rear axle over to one side. take the track bar loose & bounse the truck & let it settle. measure the height then look & see if bar will slip over the stud on axle. if it wont then mods may be in order. ours was off so much it was twisting the rear trailing arm at the bushing & rolling the truck to one side. worked for us.
andy |
