Old 03-24-2010, 07:59 AM   #1
flatblkserria82
cross member...?
Hey guys i have an 82 halfton long box that is pretty low to the ground, and i'm having a bit of trouble with the exhaust dragging right at the cross member, i was wondering if the was any after market cross members out there or if i'll have to do something else with it.
flatblkserria82 is offline   Reply With Quote
Old 03-24-2010, 08:23 AM   #2
justpball
justpball's Avatar
Re: cross member...?
so is your crossmember dragging or your exhaust?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-24-2010, 09:42 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
There are several aftermarket crossmembers available. That won't help your exhaust concerns though.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-24-2010, 10:46 AM   #4
thrtsxchambers
thrtsxchambers's Avatar
Are you running headers and if so long or short tube? If you run long tube headers they hang to low and will drag and will have to use short headers.
thrtsxchambers is offline   Reply With Quote
Old 03-24-2010, 11:45 AM   #5
flatblkserria82
there long headers, i was afraid of that, thats the only real low point of the truck is were the exhaust goes under the trans cross member on the driver side. the passenger side looks good no dragging problems or any thing...
if there is any links to these cross member parts could you send them.
Old 03-24-2010, 11:46 AM   #6
flatblkserria82
Old 03-24-2010, 08:07 PM   #7
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have long tubes on my truck and they don't hang any lower than the transmission cross member
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
