Old 03-24-2010, 11:05 AM   #1
ewoody625
ewoody625's Avatar
relocating fuel tank
Hey everyone,
I'm toying with the idea of relocating the gas tank on my 70. I'm looking to get opinions, suggestions,hints/tips. Do you have any recomendations for tank kits? My big concern is the filler location, I don't want to put the filler in the bed floor. I was thinking of putting the filler behind the license plate in the rear bumper, but I'm not sure how that will fill. I have a 2/4 drop on my truck would gravity be against me? Any suggestions for filler location would be great. Thanks in advance for your input.
Eric
70 CST10 long bed in pieces also factory air and cruise(the project)
18 Silverado crew cab 5.3 4x4
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166
ewoody625 is offline   Reply With Quote
Old 03-24-2010, 11:13 AM   #2
tomtuna1978
Re: relocating fuel tank
if you do a search .. there is a ton of info on this. but im shure tons of people will chime in and show u a lot because this is a popular subject. i personally wanna put mine behind the license plate.
tomtuna1978 is offline   Reply With Quote
Old 03-24-2010, 11:38 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'm sure you can find some examples in the build/project sub-forum.
http://67-72chevytrucks.com/vboard/s...=269754&page=6
This is a long thread, but worthy of checking out. The link above will take you to page 6 (of 24), and you can see some pix of the gas tank.
Member Nr. 2770
Old 03-24-2010, 01:41 PM   #4
cdowns
cdowns's Avatar
tthe bad about the filler in back of the rear bumper is yo need the tank to b lower than the filler// everybody tries to tuck the tank up high as possible in the frame for safty and looks
Old 03-24-2010, 01:50 PM   #5
Original67
I can't remember who it is but someone on here located it behind the side marker light on a flip out door. Side marker still works and everything. Very Very clean. I have thought about running mine through the back of the bed in one of the post holes or even coming out the back light and put it on a flip open door.
Just a thought.
Original67 is offline   Reply With Quote
Old 03-24-2010, 04:23 PM   #6
CHEMPOWR
CHEMPOWR's Avatar
I don't think there is room behind the side marker if it is a fleet side. I wanted to do it but theres not much room from the tub.
I believe the guy who did it behind the side marker had a step side.
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs
1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI
2007 Chevy Corvette ZO6 427ci 505HP
CHEMPOWR is offline   Reply With Quote
Old 03-24-2010, 05:33 PM   #7
fishingjred73
fishingjred73's Avatar
Check this out http://67-72chevytrucks.com/vboard/s...d.php?t=222461
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 03-24-2010, 08:51 PM   #8
crushermechanic
crushermechanic's Avatar
i put mine behind the back up light and ran the pipe between bed side.
crushermechanic is offline   Reply With Quote
Old 03-24-2010, 09:03 PM   #9
mmcderm
I have seen previous posts where they have installed the filler door behind the side marker light. Here is one of them.
http://67-72chevytrucks.com/vboard/s...d.php?t=368348
My sickness includes:
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
mmcderm is offline   Reply With Quote
Old 03-24-2010, 09:37 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Got my bed on today, not gonna be much room for a filler. debating which direction ima go still. I think ima graft a fuel door from a newer model..anyone know which one fits best? (slimest, because not much room behind bedsides between bedside/bedside inner)
John
1999 Toyota Tacoma 4x4
Old 03-25-2010, 10:58 AM   #11
ewoody625
ewoody625's Avatar
Thanks for all the info
Eric
Old 03-25-2010, 03:43 PM   #12
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Seems like the behind the plate filler would be too low to fill right. Might work if you are bagged and put the front in the dirt and the a$$ in the air
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-26-2010, 06:17 PM   #13
ewoody625
ewoody625's Avatar
That's what I'm thinking to gravity would be against me. I'm not baggin it so I guess I need to go back to the drawing board.
Eric
