Old 03-24-2010, 02:42 PM   #1
roofingbloke
Air suspension question
Ok guys, which should i go for,
Manual paddel valves or solenoids,
I used to have air ride on the front of my 48 ford coupe, it had two paddel valve switches, this all worked ok, obviously times have changed and everyone seems to want to go up and down fast, is this the only gain ?
roofingbloke is offline   Reply With Quote
Old 03-24-2010, 03:10 PM   #2
xJoey Dubsx
xJoey Dubsx's Avatar
Re: Air suspension question
Yes, only gain.. Less reliable, and a mess to clean up if it gets clogged.. but I run 1/2" electric valves, so who am I to say anything, haha.
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
Old 03-24-2010, 07:08 PM   #3
tubbedII
needs more $$$
tubbedII's Avatar
With electric valves, the only air line you have to run into the cab would be for the gauges...that's about the only other gain I can see.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-24-2010, 07:43 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
To me its easier to run a wire and put a switch where ever I want it, rather than plumbing all the line into the interior of the truck.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
