03-24-2010, 03:19 PM | #1 |
Roto Reuter thats the name...
Advice on steering column and shifter
Hey guys, I need some advice on either rebuilding or replacing a steering column in my 69 C20 w/ TH350. I currently have a straight column (non-tilt) with auto shift on the column. By the way, this all started from wanting to rewire the truck (which I haven't done yet). My turn signal switch is shot, need new canceling cam, bearing, safety switch, etc.
Is it better to just buy new column with all items installed, or try to rebuild? A new column might just set off the restoration (and probably my wallet). Can I install a new tilt-column? If I can use a tilt column, how hard is it to convert over to a floor shift, and what would be needed to do the job? Anyone have any remove/replace threads or info? Thanks for your help.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-24-2010, 03:59 PM | #2 |
Champagne Taste on Beer Budget
Re: Advice on steering column and shifter
I would just replace it with a tilt column.
Was thinking of doing the same thing to mine once I get to this point. Here is a link to just one vendor. http://www.classicparts.com/1967-72-...ctinfo/77-141/ And their description: Add the convenience and reliability of a new column built specific for your GM Truck. This steering column is not a universal column that requires modification of your original vehicle to install. Simply remove your old column, saving your original under-dash mount, as well as the original floor mount. Install your new steering column in place of the old. Although it is recommended to replace your original rag joint if your original is good it is a direct bolt on to the new column. A wiring adapter is included with this column for the original harness. Add an aftermarket wheel and the griping surface of the new wheel will be in the same location as the original. Also includes knobs and handles. Good luck.
Coming Soon: Project 1970 Country Truck |
03-24-2010, 04:30 PM | #3 |
The new after market column will be a good way to go if you have the money. The non tilt are not that hard to rebuild. If it needs a new shift tube it will take about $150 in parts.
03-24-2010, 10:39 PM | #4 |
Thanks. Has anyone converted their steering column from automatic column shift to floor shifter? What's involved? Also does anyone have any steps on removing the original steering column and reinstalling a new one?
03-25-2010, 08:00 AM | #5 |
Not answering your question but just adding on to:
68 here and I was thinking of taking a column out of a late model truck, anyone know of what will fit and look good? I have 4 in the floor. |
12-29-2011, 01:11 AM | #6 |
Bump. I wanna know too.
Can't piss on Chevrolets if you can't catch 'em. |
12-29-2011, 12:58 PM | #7 |
I ended up installing an Ididit tilt column and Lokar automatic shifter (Nostalgia model). Worked on it last winter. Very happy I did. I put in the chrome column. Looks great. The Nostalgia style shifter really sets it off too.
12-29-2011, 05:41 PM | #8 |
That's pretty neat. I would go with one of those Ididit columns, but I don't have the money to afford one. I also can't seem to find any of those van columns in Pick and Pull, as they don't last long if they are in there. I just said "screw it" got the column out of the same '84 Burb that I got my seat from. Has anyone worked with those? I can't seem to find any info.
