Old 03-24-2010, 05:27 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Where can I find...
...original style brake rotors for my 72 c10?
I'm talking about the ones that have the groove in them, both inside and outside.
Is it possible to find these anymore? Or are they all smooth now?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 03-24-2010, 06:23 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Where can I find...
I just converted to 5 lug on my 67 (72 front end) and they have grooves in the rotor. I thoughthey just wore the pads down at one time whats the groove for?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-24-2010, 07:49 PM   #3
killer71
killer71's Avatar
i have a set in storage!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-24-2010, 08:45 PM   #4
truckdude239
truckdude239's Avatar
mine have a groove in them i thought ti was cause someone wore the pads out
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-24-2010, 08:59 PM   #5
flashed
My truck (72) has one of each.
flashed is offline   Reply With Quote
Old 03-24-2010, 09:54 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
are they worth something? i junked mine thinking they were shot..
John
1999 Toyota Tacoma 4x4
Old 03-24-2010, 10:45 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They superceded them to the smooth rotors way back in the 70s. I'd bet you're out of luck trying to find some on the shelf anywhere.
Old 03-24-2010, 10:49 PM   #8
justcuz
justcuz's Avatar
That singular groove in the rotor was the wear limit indicator! If you junked them you threw away a perfectly good rotor. When those rotors had been turned to when the groove disappeared is when they were beyond using because they were too thin.
justcuz is offline   Reply With Quote
Old 03-24-2010, 10:57 PM   #9
toddtheodd
toddtheodd's Avatar
No... I'm not junking them. Just putting them on the shelf to save them as a momento or something.
The driver's side one is warped pretty bad, and I'm pretty sure that turning it would go past the wear limit.
I was wanting to replace them with brand new ones that looked the exact same.
I have decent pads on the truck now, but I'm pretty sure that replacing the rotors with new smooth type, but not replacing the pads would cause problems, since the pads have a ridge matching the groove, and that would have to be worn down before the total pads were making contact with the rotor.
IIOY???
Old 03-24-2010, 11:24 PM   #10
ERASER5
ERASER5's Avatar
Ding ding! We have a winner!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-25-2010, 04:03 PM   #11
justcuz
justcuz's Avatar
Todd I was telling oldblue he junked a good set of rotors. The pads with grooves in them will wear in pretty quick if you put plain rotors on. If your not comfortable with that new pads are fairly cheap.
Old 03-25-2010, 08:36 PM   #12
hayhauler71
hayhauler71's Avatar
If your trying to make them look oe, I put a set on the brake lathe at work and put the groves in a new set of rotors. Also found out that after installing the new pad and tightened down the tabs on the outside pad, that groove gives some stability to the outboard pad to prevent vibration.
hayhauler71 is offline   Reply With Quote
