03-24-2010, 05:42 PM | #1 |
drop spindels & big brakes
Which drop spindals will allow you to upgrade to aftermarket big brakes,so you don't have to switch them out at a later date?
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
03-24-2010, 07:40 PM | #2 | |
It'd be alot cooler if you did
Re: drop spindels & big brakes
http://www.classicperform.com/NewPro...op_Spindle.htm Last edited by smashingchuck; 03-24-2010 at 07:40 PM. Reason: forgot link |
03-25-2010, 12:42 PM | #3 |
the modular spindle is a 2.0" drop not a 2.5" FYI
I got a set of them recently.. they are REALLY nice! |
03-29-2010, 12:11 PM | #4 |
I am about to start working on my truck as well and researching some brake options...
The CPP modular drop spindles are nice and I want to get them, is there a way to bolt up c6 z06 calipers to them?
You can see my vehicles in my FQuick Garage. |
03-29-2010, 08:42 PM | #5 |
BMW & ASE Master Certified
The spindles tuck the wheel in 1 1/8" inwards per side... this matches the rear track width... yuck.... i almost bought a pair untill i read that
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
03-30-2010, 08:09 PM | #6 | |
Active Member
I'm sharing because with the old spindles more often than not we hear complaints about the tire rubbing and they want to lower the truck more. Danny Nix CPP |
03-30-2010, 08:33 PM | #7 |
wow... why not buy wheels with the correct back spacing?
03-30-2010, 10:41 PM | #8 |
Active Member
You can, and when youre done you will have the exact same thing as the new spindle, and an old set of front wheels. As long as youre going to buy new spindles, just buy the spindles that work and avoid buying another set of wheels.
Danny Nix CPP |
03-30-2010, 11:49 PM | #9 |
i guess when i called, they only offered the ones that were tucked in 1 1/8 " more than factory... i was hell bent on one style of wheel that i didnt even buy at the time, but in the end i bought a wheel that i loved and had the same offset. its so close enough to the fender it cut the tire once comming out of a steep drive way. rolled the fenders and havent heard a peep from the front. me personally, i strongly dislike the tucked in wheel look.
clint
03-31-2010, 03:20 AM | #10 |
Im gonna get the CPP spindles, allows you to run a deeper wheel(less backspacing) which looks better to me. I also like the idea of 13" rotors but Im not too excited about the OEM style caliper they use in their kit.
Danny, Ive got a CPP catalog(#15) and it says that the 14" kit was gonna be available late 09, any news on that? Also, would you guys sell the parts for the kit seperately(e.g. just the spindles, hubs and rotors w/o the calipers or hoses)? |
03-31-2010, 06:14 AM | #11 |
Ok maybe i should have asked wich spindel will allow you to convert to wilwood or baer brakes and calipers at a later date?
04-01-2010, 09:42 AM | #12 |
Have you looked at http://www.abspowerbrake.com/
04-01-2010, 10:05 AM | #13 |
No but I will
04-01-2010, 12:09 PM | #14 |
When I put my stock diameter rotor on my CPP modular drop spindle, the back of the rotor was hitting the spindle. Some light grinding took care of it.
