Cruzin
radiator overflow
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Re: radiator overflow
I just walked through the local junkyard looking for anything that would work. 5$ later had a bottle out of a Toyota Landcruiser that I think will work. I love recycling!
in order for the system to work properly you need to change the radiator cap
I use a 1 gallon antifreeze jug zip tied in place ...nothin pretty but it works just fine.
'70 Pontiac Firebird Esprit '72 GMC 2500 '90 GMC V1500 '94 Dodge Cummins 2500 '02 Dodge 2500 Quad Cab Long Box 4x4 gasser ![]() |
![]() Join Date: Feb 2008
I made my own using a one quart stainless drink bottle with a 3/8" brake line going to the bottom of the bottle. I drilled a 1/16" hole in the lid so it would fill and drain properly. I haven't used it yet so am not 100% sure its' right.
http://www.summitracing.com/parts/SUM-G1473/ I used this one looks great and works great.
ROFL I did the same. I just cut a hole in the lid. If i find something better in a junk yard, i'll grab it, but... truck is still a work in progress.
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400 Restoration in progress 07 Yamaha 650 V-Star Custom 83 Honda V-45 Magna Last edited by PowerPro; 03-25-2010 at 09:31 AM. |
Project '67 454
I won't be using the windshield washer system on my '67 since I smoothed the firewall so I'm using the reservoir which is already on the radiator support for the overflow.
Here's a picture Last edited by mrh33916; 03-27-2010 at 10:05 PM. |
#9 | |
"THE GREEN GOBLIN"
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
![]() Join Date: Aug 2009
I bought a universal coolant overflow bucket from Napa, cost $7. Currently it's only zip tied to the radiator support, I'd like to find something nicer looking. I like the one from Summit because you can see how much coolant is in the overflow.
Blayne |
425hp409
![]() Join Date: Oct 2008
I use the universal one from Napa, part no 730-4514, all the time for my own vehicles and my customers. It is white plastic and has mounting tabs to bolt it to the vehicle. You can see the coolant level thru it. Remember, when going to a coolant recovery system you must use a radiator cap with the rubber gasket where it seals to the top of the radiator neck.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette Last edited by 425HP409; 03-25-2010 at 10:24 AM. |
I have one from a late 70's early 80's Malibu or Caprice,I can't remember which, on my 68, it's bolted to the right inner fender, looks factory and works great.
#13 |
20' Daredevil (Ret)
![]() Join Date: May 2003
It will, as long as you change to a closed-system cap like cdowns said above.
#14 |
Autozone has a similar set up too. It's less than 10.00 and comes with the hose and steel mounting bracket. I've got it on my truck and I just put one in my brothers 71 chevelle.
Ben _____________________________________ 1971 Chevy shortbed 350/4-speed sold 2005 Chevy Duramax EC/4x4 Local 597 Pipefitters certified TIG MIG and stick welder |
#15 |
I used a 13" polished stainless steel tank from the local speed shop....It looks great and it was not crazy expenside either,.you can see it on the drivers side it looks black because it is reflecting the inner fender...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#16 | ||
"THE GREEN GOBLIN"
![]() What is the difference in the caps? How do I know what cap I have I thought they were all the same other than the lb's, My cap has a 16lb or a 17lb labeled on it?
#17 |
regular rad caps have ears on them to remove from rad closed system caps no ears mostly octagonal shaped
#18 |
Can get these for about 25 bucks on ebay, thinking this the way I'll go as well.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, ![]() 2009 Acura MDX |
#19 | |
Cruzin
#20 |
i bought a factory accessory catalog for 72 chevy trucks from jim carter truck parts and it lists a factory overflow bottle option for our trucks. right now i am using a universal kit my dad had in the attic. i screwed it to the flat vertical surface on the driver side next to the radiator. it hangs with a single stainless screw (drilled a small hole) and i ran a hose along the radiator support tucked under the top radiator brackets. the hose is pinched very slightly but it works great. the pic for the factory unit had the hose looping down and under the fan shroud.....weird.....
#21 |
huh?
![]() Join Date: May 2000
I used to use an old 16 oz. Coors can
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#22 |
You need a cap that allows the coolant to be sucked back into the radiator when it cools off, the cap will have a small steel disc type valve about the size of a dime on the inside that opens when negative pressure is in the radiator, they look like any other cap otherwise.
#23 |
universal from O'Reillys or Pep Boys works great for $10 or less
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
#24 |
dazed and confused
diet dr.pepper bottle.finished the drink then installed it.
members met: redbaron69, billsbowtie,nc67 |
#25 |
I like that stainless drink bottle idea. Fairly cheap and looks rugged. Check it every couple of weeks, level should be good. I might have to go this route.Yous guys come up with some great ideas.
