03-24-2010, 07:58 PM | #1 |
Born a Chevy Man
'81-'87 Cluster & Tach
There is a true '81-'87 Factory cluster and tach on ebay. I know these are hard to come by.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
03-24-2010, 09:45 PM | #2 |
Re: '81-'87 Cluster & Tach
87 black silverado swb, tbi 350, 700r4, 3.40 gears. 2.5 drop spindles , 2 inches off stock coils, flip kit out back. cragers with radial ta's... ongoing piddle project! 1970 Olds rallye 350, street strip 403/350 3.73 posi. Looks stock/runnin 12's! 86 K5- SOLD! |
03-24-2010, 10:53 PM | #3 |
that is for an 80-86, and if your truck has cruise it wont work anymore with that cluster
03-25-2010, 12:00 AM | #4 |
[QUOTE=95 S_Trucker;3880437]that is for an 80-86, and if your truck has cruise it wont work anymore with that cluster[/QUOT
i may be wrong but 73-80 is the same and 81-87 are differant i put factory tach in both my 78 and 85 and the cruise still worked in both can you explain this for me i've seen alot of 80-87 talk on here as that being the change over for the front end ,glass and int change are there some 80 trucks that saw the change over? its alway's been 73-80 and 81-87 to me just curious
sure bow ties are for little boys ....[B]but ponys are for little girls |
03-25-2010, 08:23 AM | #5 | |
I *think* 87 might be unique because it was the first year for TBI. That changed the Vehicle Speed Sensor in the back of the cluster, which is what would affect the cruise (Not because of the front end change or anything like that). For your other question, there were no 80 trucks that saw the front end change. You are correct when you say the model years were 73-80 and then 81 on up. Incidently, I saw the '81 front end before it came out and I didn't like it. I hurried and ordered an '80 before it was too late. But - I did the same thing later, too. I saw the GMT400 version for '88, didn't like it and hurried to order an '87 before it was too late. That's the truck I still have. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-25-2010 at 08:28 AM. |
03-25-2010, 08:28 AM | #6 | |
[quote=snc4life;3880564]
it would be a direct fit for 78-86, but the font for the gauge faces changed in 80, it wont work on a 87 because there is not a VSS on the back of the speedo the cruise control trucks have a little green box that plugs into the back of the speedo, that started in 83, my 85 had this, no more cruise for me the cluster posted does not have a spot for the green box to plug into and it wont work in an 87 unless you remove the TBI. The ecm requires a vss signal, and the vss was mounted to the back of the speedo. If you use the speedo your truck originally came with, the cruise would work on an 83 and up. you would need to cut the back of the cluster to get the vss to fit Last edited by 95 S_Trucker; 03-25-2010 at 08:45 AM. |
03-25-2010, 10:01 AM | #7 | |
you seem very knowledgable about this stuff-
would a guy with a 87 need to have a "87" specific tach set up to work right? curious...thanks [quote=95 S_Trucker;3880911] Quote:
1987 350 TBI lowered 5/7 |
03-25-2010, 12:28 PM | #8 |
[quote=bigarmzz;3881027]you seem very knowledgable about this stuff-
would a guy with a 87 need to have a "87" specific tach set up to work right? curious...thanks i *think* you could get an 78-86 if you wanted, and trim the white cluster housing so your original speedo with vss would fit in it. Im not sure if the circuit board or pins changed from 86-87 |
