700 auto transmission from 1990/91 for C10 69
I´ve a C10 69 with 350 engine and 4 speed compound manual transmission, and I want to start to collect all the parts in order to make the conversion to automatic.
I found at the junkyard a 700 transmmission in a Camaro 90 or 91. Can I use that transmission? or can you suggest other years. thanks. ![]() ![]() ![]() ![]() |
Re: 700 auto transmission from 1990/91 for C10 69
Yea you can use it. I would get a 700r4 crossmember from Early Classic or CPP.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
425hp409
![]() Join Date: Oct 2008
I put a 700R4 in my 68 by just moving the existing crossmember back and drilling new holes in the frame. If you are going to leave the existing steering column in place, you can use a floor shifter. If you want a column shift, you will have to change the steering column and find the correct bracket to connect the linkage from the frame to the transmission. I got mine from a late model van with a 700R4. It would be easiest to use a floor shifter as the transmission already has the brackets for the shift cable and you could keep your column.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
I put a 700R4 in my 68'.
Sourced the cross-member from Bow Tie Overdrives The floor shifter from Lokar (shifter DIDN'T require cutting a new hole in the floor board, althought it attached to the top of the transmission and is operated by a linkage rather than a cable). The shifter handle is pretty tall . . . 20 or 23 inches I think with two bends . . . knob ends up in front of the radio at about the same level. Need to change the driveshaft length, and get a different front slip yoke. Pending carb, you may need a throttle valve cable bracket. |
thanks for the information, I still having a question,this car has computer and our old trucks don´t .
![]() Join Date: Jan 2010
you don't need a compute.Only elec. is the lock up for the converter. very simple to do
thank you again, if a member of a board has pictures of all the parts a will need I´d like to see them.
How late did the 700r4s have mechanical speedos?
my 700 came out of an 84 wagon, and it has cable driven speedo.
67 short bed stepside tach tilt buddy buckets bagged sittin on 20s and 4w disc brakes (not quite finnished) ![]() |
huh?
![]() Join Date: May 2000
I have one out of an 88 pickup that has a cable driven speedo, I'm thinking 88-ish is around the time they went to an electronic speedo though.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
