Old 03-25-2010, 12:03 AM   #1
jess66chevy
jess66chevy's Avatar
Benefits of new BALL JOINTS?
Hey guys,
dumb questions but tell me why a new set of ball joints (upper and lower) will effect the suspension. Mine are worn out on my 66. I just want to understand the ball joints function. Thanks.
jess66chevy is offline   Reply With Quote
Old 03-25-2010, 02:45 AM   #2
draggin86
draggin86's Avatar
Re: Benefits of new BALL JOINTS?
think of it this way just like old people there joints wear out and they aren't held into the socket as well because the material used to help them move around wears away.. there for they are more prone to break or even pop out.. you should be able to feel the play in the ball joints but pulling up on them and moving them back and forth.. if they aren't replaced when worn there is possibility of failure of the ball joint and loosing control of your truck. so good idea to replace them.
draggin86 is offline   Reply With Quote
Old 03-26-2010, 07:48 PM   #3
jess66chevy
Thanks for the info. Another question, does it effect ride quality?
Old 03-26-2010, 09:10 PM   #4
mullit
mullit's Avatar
premature tire wear
mullit is offline   Reply With Quote
Old 03-26-2010, 09:41 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You are torturing your brake hose by letting the spindle hang like that. Look how tight it's pulled.
Old 03-26-2010, 09:52 PM   #6
ERASER5
ERASER5's Avatar
X2!
If your brakes "stick" and burn after you do the ball joints, a bad brake hose will be the reason. Hanging the caliper is very bad on an old hose, let along the A-arm and spindle too. Bad on a new one too for that matter.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
