![]() Join Date: Jul 2009
Some lowering questions
I am sure this has been covered a billion times, but I couldn't find a definite answer so I'm gonna ask for one
![]() I have a '76 2wd Blazer that the PO decided to make look like a 4wd by using 3" blocks and coil over shocks in the rear and longer front coil springs and coil over shocks on the front...and I HATE IT THIS WAY! It's time to drop it. I only want to lower it about 3-4" in the front with a spindle and coil spring. I have read a lot about issues with lowering the rear. I want to lower the rear about 4", but I know there isn't a shackle/hanger set up for these. I have the brackets to do the flip that I made for my '87 so I can do the flip, but what leaf springs do I need to get to put back on it to "raise" it to the 4" mark? |
Re: Some lowering questions
I thought I read somewhere that you could use the 4x4 leaf springs from a later model or something to achieve this too?
Low & Fast!
You both are close, but I did use 4x4 leafs off 2door 92-95 blazer/Tahoe, not sure if the 96-99 will work. But I used this with the flip kit.
Trav
Travis, I thought I saw that somewhere. If I get the leaf springs from the 92-95 4x4 Tahoe and use it with the flip kit, what kind of drop should I expect?
Low & Fast!
about 4-5"
I know the pieces fit
I totally missed that leaf spring trick. There's so many tricks to lowering these I'm not sure I'll ever get a good handle on it.
I went and got a set of the '95 4x4 rear leaf springs today. I have to wait for the spindles and coil springs to get here and then it will "begin". Hopefully this will work out...I have a lot of faith in Travis though!
Trav's got that thing dialed in tight. If you want to go that low, following his recipe is the way to do it.
#13 |
Well today i went to go buy some parts for my blazer, i was originally going there for tailgate and back glass but came home with more than that!! on this parts truck that i found was a bell tech rear shackles and lowered spindles and springs. when taken off the right rear shackle i noticed that the shackle was pinching the fuel neck hose, i will keep my eye on this thread and keep u guys updated on the installation! I do want to go as low as possilbe without cutting the floor ane removing the rear seat. Please keep us posted on how the 92 - 95 leaf springs work for you!! thank you
1977 Chevy Blazer |
#14 | |
Low & Fast!
And hope that works out for you guys like it did for me.. ![]()
#15 |
http://eatonsprings.com/73-79chevroletblazer.html Here is a great way to resolve your ride height issues for use with flip kit. springs come in +1,2 or 3" option.
79 2wd Blazer/ flip kit, drop spindles, drop springs. 355 c.i. sbc, 350 tranny |
#16 |
The shackles don't work without mods. hope everyone reads this. It made me a lol angry
Posted via Mobile Device |
#17 |
It's been done before. This is from some friends of mine helping me with my '79 in one of their shops.
This one of my bud's, he learned to weld in a muffler shop. He cut up my fuel filler neck and welded it back up with a few bends in it then finished it out until it was water-tight. ![]() Here it is on the truck. ![]() ![]() Works well. |
#18 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Forget the shackles.
Use drop leaf springs or a flip kit.
#19 |
