Old 03-25-2010, 11:29 AM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Convert column shift to floor shift
My 69 C20 has TH350 and I'm looking to change steering column. Has anyone converted their automatic column shift to floor shift? What's involved and what would I need? Any recommendations?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-25-2010, 12:41 PM   #2
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: Convert column shift to floor shift
You can get most any universal floor shifter (Lokar, B&M etc) with the cable linkage for an automatic. Some are better than others, B&M is just shiney plastic crap IMHO but they work most of the time and are affordable.
Down side is you will have to make a hole in the floor for the shifter cable.
And a lot of guys just remove the stock shift linkage, and pop out the roll pin on the shifter handle and remove it. But if you are getting a new column then no worries there.
Hope this helps, some better educated guys will chime in with specifics I'm sure.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 03-25-2010, 12:52 PM   #3
derotoreut
derotoreut's Avatar
Thanks for the info. You mention making a hole in the floor for the cable. Do you recommend using a shifter with linkage or cable? I'm not familiar with the cable. How does that work on a tranny like the TH350?
~ Dan
Old 03-25-2010, 01:06 PM   #4
Leviticus
Shake and Bake!
Leviticus's Avatar
Here is a picture of a late model car with a cable op shifter, sorry I couldn't find a pic of a TH350. But you will get the general idea.
Thomas Jefferson
Old 03-25-2010, 01:10 PM   #5
Leviticus
Shake and Bake!
Leviticus's Avatar
The TH350 will have two factory mounting points on the drivers side just above the pan lip, I'm pretty sure if you get a shifter compatible with a TH350 it comes with a bracket that bolts to those holes with a cable bracket.
I would go with a direct linkage type Lokar though if you don't mind spending a little extra $.
Thomas Jefferson
Old 03-25-2010, 01:43 PM   #6
derotoreut
derotoreut's Avatar
I saw where Hurst has a shifter kit for pickups with auto trannys. Any feedback?
INDY PICKUP TRUCK 3-SPEED SHIFTER
This popular Indy shifter is available for pick-up trucks and is a perfect replacement for old floor shifters, or an ideal column shift conversion.
• Fits many popular 2 and 3-speed automatic transmissions
• Universal floor mount for easy installation, ideal for column shifter conversion
• Safety detented for precise shifting control
• Linkage rod activated
• All parts are plated for lasting protection
• Easy to follow installation guide
• Must use factory neutral safety switch
• Extended chrome-plated stick (uses 3/8-24 thread) to accommodate pick-up truck seat height
• Precise selector pin mechanism
• Spring loaded gate for positive shifts
• All parts plated for protection
• Stamped with Hurst/Indy identification
• Complete with all linkage, mounting hardware, and easy to follow installation guide
• Shown with optional knob & Indy Boot & Plate #114 8429, recommended for finished appearance
5010016
Weight: 8.05 lb
Price: $142.50
~ Dan
Old 03-25-2010, 02:01 PM   #7
Leviticus
Shake and Bake!
Leviticus's Avatar
Hurst makes a nice product, I had one of their shifters in my 65 Burb and liked it.
Thomas Jefferson
Old 03-25-2010, 02:12 PM   #8
derotoreut
derotoreut's Avatar
I spoke to a fellow at Lokar who told me before he can recommend anything, I need to look at where I want to mount the shifter in relationship to the transmission. In other words will the shifter be mounted over the tailshaft or more over the bellhousing. Depending on where that is mounted will dictate if I need a cable activated or can go with a direct linkage type shifter. He said the direct linkage is less expensive. They also come with neutral safety switch and an option for backup lights.
Can you tell me anything about kick down linkage? I don't know anything about it for this truck. Is there something that's supposed to go back to the carb?
I have an Edelbrock 1405 carb. Doesn't look like there's anything hooked to it. There isn't even a choke connected (manual or electric).
~ Dan
Old 03-25-2010, 04:28 PM   #9
Leviticus
Shake and Bake!
Leviticus's Avatar
Your kick down cable should not be a factor when dealing with a shifter, as far as I know. Your kick down cable goes into the passenger side of the TH350 by the cooling lines IIRC.
A cable operated setup is much easier to install, but I have had my share of problems with them after they age, I think if you can get some lube in the cable every so often, it should be fine.
As far as mounting location, you will have to climb under the truck and take some measurements from where you want the shifter on the hump, to the distance to you gear selector arm.
Thomas Jefferson
Old 03-25-2010, 05:59 PM   #10
derotoreut
derotoreut's Avatar
What exactly does the kick down cable connect to on the tranny? Where does it go to from there and what does it do? Is it a manual linkage type cable that pulls on the carb or something?
~ Dan
Old 08-14-2010, 05:43 PM   #11
67rookie
I purchased a 1967 c10 that someone had converted it from three on the tree to a floor shifter. I would like to put it back. The original column is in the truck and I purchased the shifter for the column and 4(?) shift rods. But I have no clue how to route them or if I have everything I need. I was wondering if anyone had a diagram, pictures, or could possibly explain how they go, thanks -Rookie
67rookie is offline   Reply With Quote
