Old 02-05-2003, 09:16 PM   #1
KWinBigE
Question dash light problem
First, I just bought a 71 Custom 10 and I sure appreciate what a wealth of knowledge there is on this board. Already picked up a lot of good info.
But.....
Here's one I haven't seen before.
The dash lights on my '71 work but are real dim. I turn the knob all the way just short of the dome light coming on and they get a little brighter but still very dim. All external lights and signals work as advertised.
Here's some possible clues.
Both turn indicators come on (and stay on) when I turn on the lights, but the signals and flashers still work fine.
The dash lights are even dimmer when the high beams are on.
The dash was replaced with a tach dash (before I got the truck).
I'm thinking it might be a printed circuit board problem?
Any suggestions for troubleshooting further will be appreciated.
Thanks,
Kim
71 Custom 10, LWB
RED, RED, RED
KWinBigE is offline   Reply With Quote
Old 02-06-2003, 09:56 AM   #2
JimKshortstep4x4
Talking
Everything that you describe indicates a ground problem. The dash gets its ground through the connector that plugs into the dash. I would suggest adding a separate ground wire and attach it to the metal back of the dash.
Jim
Old 02-06-2003, 10:16 AM   #3
cdowns
cdowns's Avatar
Adding an additional ground wire is a good idea if that doesnt help you could always try new bulbs
Old 02-06-2003, 01:06 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I had exact same problem. It was a ground on the circit board. I found it by accident when I grounded the unit while trying to figure it out. Just a loose ground, now they work PERFECT
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 02-09-2003, 11:16 PM   #5
GMC Jim
GMC Jim's Avatar
I replaced the #194 lamps with #168 lamps which are 3 CP compared to 2 CP... ( 1/3 brighter! )... leave the headlamp ho/lo indicator lamp with the original 194 lamp...
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
