67 Chevy Stepside
Will a cab and chassis 14 bolt ff with dual wheels
can i take the 14 ff dual wheels out of a cab and chassis and make it into a single wheel rearend to go under a 79 crew cab
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
Location: Where I come from, it's cornbread and chicken...
Re: Will a cab and chassis 14 bolt ff with dual wheels
you can but the wheels will be really sunken in...the cab and chassis rear ends puts the inner wheels which would be where your wheels would be srw right beside the frame rail...those rearends are designed to run both wheels under the bed...
67 Chevy Stepside
so what 14ff will fit under my crew cab
Real Projects never die
if you want to run dually fenders use one from a dually, not a cab and chasis.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
a srw 14 bolt ff will fit with the wheels in the factory location...a cab and chassis rear will fit, but the wheels will just be tucked way in by the frame...
67 Chevy Stepside
i want to go from a dually to srw got a dana 70 now
get a 14ff from a 1 ton single wheel then.
pm sent
i saw F**D once that was a CCLB with a cab and chassis rear end in it. 4x4 lifted.. it actually looked really cool. i like the concept of duallys but im not a big fan of the looks of the back wheels sticking way out there. i always wanted to put a cab and chassis rear end under a 4x4 cclb chevy. i think it would be awesome
"I'll keep my guns, money, and freedom. You can keep the "change" |
Extended cab fanatic
You can put a single wheel on it now. Just get the right offest, and bolt it on. I dont see any reason to swap the axle when all you need to do is get the correct offset/backspacing for your wheels
If it has a motor, it has my attention. |
he found a 14 bolt FF that will fit perfectly under there...
