Raining In my 72 Cab
Every time it rains my cab floor is getting wet .The passenger side seems to be coming in at the antenna hole which will be easy enough to seal. The driver side is dripping onto the parking brake lever. I have removed the old seamsealer in the corner on both sides below the windshield and put fresh seam sealer in those areas and it still leaks. Have not yet sealed inside the cowl area below the wiper assembly but hope to this weekend.Any other ideas where to look ?
Re: Raining In my 72 Cab
Have you checked the top cab seam? If it hasn't been re-caulcked you can get water in there rusting out the top inside of the windshield area. Check that and where the seam goes on top of the drip rails over your doors.
Will check those areas as well ,thanks for the suggestions .
